17267 Discussions
Take a time to program Flash with PFL
I programed 64Mb flash rom on my board through MAX-II PFL with USB-Blaster cable, and it took about 20 minutes. It is too slow even when I take slow JTAG and flash access into consideration. I tried with using command line and standalone programmer module, but neither improve the situation.
Do someone know the way to speed up?
Which version of Quartus II are you using?
It's best to use the latest version.
Thank you for your reply. I'm using V7.1sp1, so I will try it with v7.2.
