Ankündigungen
17268 Diskussionen
Test benching LVDS ports
Geehrter Beitragender II
1.467Aufrufe
I have a Verilog design that I'm simulating with a Verilog test bench using Altera-ModelSim. The desgin has LVDS ports and when the simulation is run ModelSim complains about unconnected xxx(n) ports, the negative LVDS inputs. How do I specify the driving of these ports from the test bench when the Verilog design doesn't have explicit ports for the negative LVDS pins?
2 Antworten
722Aufrufe
you must be doing a gate level simulation? you may have to drive the -n legs from your test bench
722Aufrufe
Yes this is a gate level sim. How do I drive the (n) pins from the Verilog test bench? Or, how do I explicitly define the (n) pins in the device Verilog file? I just left the (n) pins undefined and Quartus automatically assigned them, so there is no definition for these pins in the Verilog design file. Is there a way to explicitly define the (n) pins in the design file?
Antworten
