I am a new learner for ModelSim, and I have met some problems about it.
I have made a simple dff using lpm_ff, the code is showed below module fddf(clk,clear,q); input clk, clear; output q; lpm_ff f1(.enable(1'b1),.clock(clk),.sclr(1'b0),.data(clear),.q(q)); defparam f1.lpm_width=1, f1.lpm_fftype = "dff"; endmoduleand I have write test bench for it, the code is showed below `timescale 1 ps/ 1 ps module fddf_vlg_tst(); // constants // general purpose registers reg eachvec; // test vector input registers reg clear; reg clk; // wires wire q; // assign statements (if any) fddf i1 ( // port map - connection between master ports and signals/registers .clear(clear), .clk(clk), .q(q) ); initial begin // code that executes only once // insert code here --> begin clk=0; clear=0; // --> end $display("running testbench"); end always # 25 clk = ~clk ; endmodule
But when I use ModelSim-Altera to simulate it, such error comes out: error: (vsim-10000) c:/users/tei.ylib_tei-pc/desktop/dff3/fddf.v(10): unresolved defparam reference to 'lpm_width' in f1.lpm_width.
error: (vsim-10000) c:/users/tei.ylib_tei-pc/desktop/dff3/fddf.v(11): unresolved defparam reference to 'lpm_fftype' in f1.lpm_fftype.
The file I added to the ModelSim-Altera project is the design file and testbech file, also, the 220model.v and altera_mf.v, cycloneiii_atoms.v are included. I am quiet confused about how to simulate the lpm parts, please help me , Thanks.
I am sorry the problem solved. Use lpm_ff#(1) f1.(.....) can solve the problem.
