The quartus II (V9.1) could generate output files normoly when choose EP4SE520, but it couldn't work when choosed EP4SE820:(
The massege is : Warning :Can't generate output files. Specify command-line options to generate output files,or updata EDA tool setting using GUI or Tcl script. Could sombody help me?Link Copied
for the EP4SE820 there is only the advanced device support in this quartus version. This means quartus does not generate any programming files. You should update your quartus version. You can check the supported devices in the "Quartus Software Device Support Release Notes for Quartus xx" document.- Mark as New
well just to say the message could have been a little more explicit. I already got this message with previous versions and there was a reason to it so when i got it here i searched for 1 day before searching the answer here...
