16720 Discussions
The use of shift SRL, SLL..
hello everybody, (sorry if I do not write well in english but i'm a poor student...)
I have some problem with the use of the shift operators..
The goal of the program is realized an iir filter of order 2.
I want shift right an integer ( acc) but the altera compiler will not let me .. it gets angry! why?
it generate error: error (10327): VHDL error at filter_iir.vhd(81): can't determine definition of operator ""sll"" -- found 0 possible definitions
So i think that there is a problem about library i include a lot of library but the compiler it's always angry! why? :confused:
i enclose my code here:
--file1
PACKAGE n_bit_int IS
SUBTYPE BITS11 IS INTEGER RANGE 0 TO 1023; -- 11 bit
SUBTYPE BITS22 IS INTEGER RANGE 0 TO 2097151; -- 22 bit
SUBTYPE BITS15 IS INTEGER RANGE 0 TO 32768; -- 15 bit
SUBTYPE BITS14 IS INTEGER RANGE 0 TO 16384; -- 14 bit
TYPE ARRAY_BITS15 IS ARRAY(NATURAL RANGE <>) OF BITS15;
TYPE ARRAY_BITS11 IS ARRAY(NATURAL RANGE <>) OF BITS11;
TYPE ARRAY_BITS22 IS ARRAY(NATURAL RANGE <>) OF BITS22;
TYPE ARRAY_BITS14 IS ARRAY(NATURAL RANGE <>) OF BITS14;
END n_bit_int;
--file2
LIBRARY work;
USE work.n_bit_int.ALL;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
use ieee.numeric_std.all;
use ieee.std_logic_signed.all;
ENTITY filter_iir IS
GENERIC ( L: INTEGER :=3; -- order filter L-1
W1: INTEGER :=11;
W2: INTEGER :=22;
W3: INTEGER :=15;
W4: INTEGER :=14
PORT ( x_in :IN BITS11; --INPUT
y_out :OUT BITS14; --RESULT
debugx :OUT BITS22;
debugx1 :OUT BITS22;
debugx2 :OUT BITS22;
debugx3 :OUT BITS22;
debugy0 :OUT BITS15;
debugy1 :OUT BITS15;
debugy2 :OUT BITS15;
clk : IN STD_LOGIC);
END filter_iir;
ARCHITECTURE myiir of FILTER_IIR IS
SIGNAL x : ARRAY_BITS11 (0 TO L-1);
SIGNAL x_num : ARRAY_BITS22 (0 TO L-1);
SIGNAL i,j : integer :=0;
shared variable y_den: ARRAY_BITS22(0 TO L-2);
shared variable y : ARRAY_BITS15(0 TO L-2);
shared variable acc : integer;
BEGIN
PROCESS
BEGIN
WAIT UNTIL clk='1';
-- esempio butterworth ordine 2
x(0)<=x_in;
x_num(0)<=281*x(0); -- b0x(k)
debugx<=x_num(0);
x_num(1)<=562*x(1); -- b1x(k-1)
debugx1<=x_num(1);
x_num(2)<=281*x(2); -- b2x(k-2)
debugx2<=x_num(2);
for i in 0 to L-2 loop
x(i+1)<=x(i);
end loop;
for j in 0 to L-3 loop
y(j+1):=y(j);
end loop;
y(0):=(x_num(0)+x_num(1)+x_num(2)+y_den(0)+y_den(1));
debugy0<=y(0);
acc:=y(0);
y(0):= acc sll 10;
y_den(0):=-75*y(0); -- a1y(k-1)
debugy1<=y_den(0);
y_den(1):=176*y(1); -- a2y(k-2)
debugy2<=y_den(1);
end process;
y_out<=y(0);
end myiir;
Somebody can you help me?
thank you!:rolleyes:
good Easter!
Enrico
In numeric_std, sll is defined for signed and unsigned.
So you need to convert your integer to unsigned, then convert the result back to integer
y(0) := to_integer( to_unsigned(acc, 16) sll 10 );
And pre-empting the next post about it still not working, you need to delete std_logic_arith from the libraries (you shouldnt be using it anyway as it's non-standard).
