In my sdc file I have a set_input delay command as
set_input_delay -add_delay -clock { dctu_i|a_uniphy_i|a_uniphy_inst|pll0|pll_afi_clk } -min -0.01 [get_ports { my_signal}] I keep getting the following warning from this line ignored set_input_delay at myfile.sdc(116): argument -clock is not an object id If I do a report clocks, I can see the clock name dctu_i|a_uniphy_i|a_uniphy_inst|pll0|pll_afi_clk Anyone got any ideas why I am getting this warning? Your help is very much appreciated CLink Copied
Run report_clocks and see if it shows up there. I usually copy from that report to make sure I get the name correct. The other possibility is that the set_input_delay is created before that clock gets generated, so the name is correct but the order isn't.
Rysc,
Thanks for your reply. It is the latter that is the problem. My .sdc script order had magically changed around in the quartus settings. As I use the read sdc macro command from the left hand side of the timequest quest GUI, I think it uses the order in the Quartus settings. Problem solved now. Thanks Rysc C
