17267 Discussions
Timing Constraints in DCFIFO through LPM
skyjuice88
DCFIFO if generated through IP catalog will have the associated SDC constraints as well (set_max_delay/set_min_delay, set_net_delay and set_max_skew).
What about DCFIFO instantiated through LPM (https://www.intel.com/content/www/us/en/docs/programmable/772350/23-3/asynchronous-fifo-parameterizable-macro-69581.html)
We use LPM for some of the IPs and would want confirmation if all the constraints are also included in LPM method.
RichardTanSY_Altera
There is no associated sdc generated through LPM.
If you choose to code your own dual clock FIFO, you must also create appropriate timing constraints in Synopsis Design Constraints format (.sdc).
Reference:
https://www.intel.com/content/www/us/en/docs/programmable/683082/23-1/dual-clock-fifo-timing-constraints.html
Richard Tan
skyjuice88
Hi Richard Tan,
The document that you pointed out refers to FIFO that is written through RTL inference. Can I confirm the same applies to LPM instantiation which is using the template provided by Quartus?
In Quartus --> Edit --> Edit Template --> Verilog HDL --> Intel Parameterizable Macros --> async_fifo
RichardTanSY_Altera
Yes, you are right. If you want the SDC to be generated, I would advise using the FIFO Intel FPGA IP to generate the SDC when click the 'Generate HDL.'
Richard Tan
skyjuice88
Thanks for the confirmation. I have no more question.
RichardTanSY_Altera
 I'm pleased to know that your question has been addressed.
Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Thank you and have a great day!
Richard Tan
