17255 Discussions
Transceiver Toolkit and Hierarchical Qsys Design
Just curious but has anyone gotten this to work? The examples seem to work fine but when I try to push into a reusable block, I can't seem to fully link up to the transceivers. I basically saved my working qsys design, removed the JTAG component, exported the necessary signals (generator, checker, phy management) and connected everything in a top level project. I have to manually create the transmit, receive and transceiver channels in the toolkit and that works but I can't get eyeq to come up. The button is grayed out but I'm not quite sure what else it needs. :confused:
The qsys system gets out of hand pretty quickly with multiple transceiver instances and I'd like to ability to test as many transceivers in a single project as I can. It seems as though System Console has enough dependencies on the Quartus project as a whole that I'd have to create a separate project per toolkit instance. Not a killer but it seems so close.
Scott
