17268 Discussions
Transceiver Toolkit for Serial Lite III
host
Hello.
I'd like to connect an Arria 10 and a Stratix 10 FPGA with a 4 lane Serial Lite III duplex interface.
Should I use Intel's Transceiver Toolkit to debug the design? Or is there a more recommended tool for Serial Lite III ?
ZiYing_Intel
I would more recommend toward using Serial Lite III Streaming Intel FPGA IP. Serial Lite III Streaming Intel FPGA IP is a high-speed serial communication protocol for chip-to-chip, board-to-board, and backplane application data transfers. This protocol offers high bandwidth, low overhead frames, low I/O count, and supports scalability in both number of lanes and lane speed.
The Serial Lite III Streaming Intel FPGA IP incorporates a media access control (MAC) block, a physical coding sublayer (PCS), and a physical media attachment (PMA). The IP transmits and receives streaming data through the Avalon® streaming interface on its FPGA fabric interface.
For further details about the Serial Lite III IP support in Intel Stratix 10 and Arria 10 devices, please do refer link below, Section 2.3, https://www.intel.com/content/www/us/en/docs/programmable/683330/22-4-20-0-0/performance-and-resource-utilization.html
Zi Ying
host
I'm sorry, but this doesn't answer my question.
I'm asking about using the Transceiver Toolkit together with the Serial Lite III IP.
ZiYing_Intel
It need depends on your project requirement but it was suggested to use the Intel's transceiver toolkit with Serial Lite III IP. For your information, Serial Lite III only supports Intel® Stratix® 10, Intel® Arria® 10 Arria® V GZ, and Stratix® V FPGA devices.
zying
ZiYing_Intel
Do you still have any question about this case?
Zi Ying
ZiYing_Intel
Since no hear any feedback from you, I am now close the case. If you have any issue after the case closed, please do feel free to submit another issue.
zying
