17253 Discussions
Transceiver Toolkit <=> ALTGX interface
Hi everyone,
I am currently working on a project involving a Stratix IV GX FPGA, and several transceivers.
In order to ensure a good signal quality, I would like to dynamically reconfigure the transceivers using the Transceiver Toolkit.
Now, here is my question :
In the "Transceiver Link Debugging Using the System Console" documentation the only mentioned Transceiver IP is the Transceiver PHY IP, instancied in QSys. Unfortunately, my project is based on the ALTGX and ALTGX_RECONFIG IPs, and I couldn't find any example interfacing these with the Transceiver Toolkit... :confused:
Is it simply just ALTGX IP is older than Transceiver PHY IP, which means that it is possible but not documented, or is it because it is impossible to use the Transceiver Toolkit with ALTGX instances ?
Thank you so much for your time, and have a nive day.
Regards.
