17268 Discussions
Tristate outputs - how to?
I want to tristate a group of outputs based on the state of an input pin (MAX7000S).
I have found the TRI megafunction but it looks like this uses additional resources that shouldn't be necessary. I can see that the I/O control block has a tristate buffer for the I/O pin, so it would appear that I can use this for "free", i.e., without consuming additional resources. I think I need to configure the pins as BIDIR but I can't see how to access/set the global enable for the pins that I want to control.
Can someone tell me where to find this in Quartus please?
Where do I configure the output enables?
Can I set the global enables on a bdf, or do I need to use VHDL to code the control action?
regards
Dave
I don't see any of the problems you are considering.
You want use schematic entry, O.K. You'll either place alt_io_buf (for bidirectional pins) or alt_out_buf or tri symbols (tristate output only) and connect the tristate inputs to the respective enable signal.
Did you observe any problems when doing so? If yes, what is it?
Hi FvM,
thanks very much for the reply - when I went back to this, I saw that I had made an error, things work just as you describe !
regards
Dave
--- Quote Start ---
--- Quote End ---
OK, so far so good. But what does the output of the TRI symbol connect to? How do I get a pin name pin name/number assigned to the TRI output?
ak
Answering my own question because Altera tech support does not exist. To create a tri-state output pin, connect the output of a TRI or TRI-BUF library part directly to the input of an output pin library part. The compiler will interpret this to mean you want a tri-state pin. The TRI control input is non-inverting - a high on the control enables the device output pin. A low on the control input puts the device pin in tri-state.
ak
