17249 Discussions
Trying to Simulate PLL MegaFunction In ModelSim
I'm pretty new to using modelsim. I have a really simple design with just a PLL, and I wanted to test it using modelsim. However, when I try to run the simulation I get an error stating the following:
Error: (vsim-3033) D:/altera/11.0/testproject/testpll_syn.v(141): Instantiation of 'testpll_altpll' failed. The design unit was not found.
I guess I'm missing something in my library? I'm pretty lost so if someone could point me in the right direction I'd really appreciate it.
I assume that you're simulatin using Modelsim and a testbench.
Are you sure the you instantiate design to be simulated using the verilog name otf the file that contains the PLL?
Do you have in you design directory the files:
altpll0.v altpllo.qip etcetera?
Yes, I have all those files in my design directory. And I'm pretty sure its being instantiated correctly.
Should be something simple.
Can you devise what testpll_altpll is?
Is it the top level entity of your design?
Can you upload your testbench and the files that describe your design?
