17259 Discussions
UART receiver loopback characters VHDL
Tex
Greetings,
I'm new to the world of FPGA's
could anyone suggest me anything that helps me to learn implementing UART serial communication receiver loopback characters without state machines in VHDL
Tex
ShengN_Intel
Hi Tex,
You may check on this first example design link:
https://github.com/Domipheus/UART
https://domipheus.com/blog/a-uart-implementation-in-vhdl/
Make appropriate connection between O_tx and I_rx to form a loopback. The simulation result like below:
This is second example design link (apparently state machine):
https://nandland.com/project-7-uart-part-1-receive-data-from-computer/
https://www.edaplayground.com/x/7Em
https://www.edaplayground.com/x/5vEh
https://nandland.com/7-segment-display/
Make appropriate connection between o_TX_Serial and i_RX_Serial to form a loopback. The simulation result like below:
Sheng
FvM
please elaborate your question. UART receiver implementation in VHDL is more or less clear, how is it specifically related to loopback?
What's your problem with state machines?
Tex
Thanks for your reply,
I'm a student, I would like to learn UART with fpga in VHDL
loopback what i mean is, if i enter in the keyboard any character it should display in the serial monitor
i'm thinking state machines are tough to learn
please help me with any kind of tutorials where i can learn it or any codes
best regards,
Tex
_AK6DN_
Valued Contributor II
The concept of 'state machines' is not hard to learn, and in fact is indispensable when it comes to digital design in general.
So I suggest you pursue learning state machine concepts, be it graphically or encoding the state machine into VHDL.
It will make your life so much easier and more enjoyable when it comes to using FPGA technology.
Here is a simple tutorial centered around using VHDL (I am a verilog guy myself):
https://circuitdigest.com/microcontroller-projects/implementing-finite-state-machine-design-in-vhdl-using-modelsim
There are lots of other tutorials on the web and youtube.
Tex
Thanks for your valuable reply that's very help full tutorial for receiving
I'm trying to achieve whatever the character i press in the keyboard it should receive in the serial monitor
could you please help me
Tex
ShengN_Intel
Hi Tex,
Sheng
Tex
Tex
Thank you sheng this helped me alot..
for the link 1
when i try to assain pins there are showing more than 50
please tell me which pins should i assaign only 3 enough ???
regards,
Tex
ShengN_Intel
Hi Tex,
Pins that should be assgined:
I_clk
I_reset
I_txData (If you're getting the data externally from the board, then needed. Otherwise, not needed)
O_tx, I_rx (Needed as to make loopback connection)
O_rxData (If you're showing the received data externally to the board like LED or Monitor, then needed. Otherwise, not needed)
For this I_txSig, you can comment out this input port and the rest in the code if you're not using it.
For I_rxCont and I_clk_baud_count, you can declare them as signal instead of input port so that not need to make any pin assignment. For example like below:
signal I_clk_baud_count : STD_LOGIC_VECTOR(15 downto 0) := X"01B2"; -- 115200bps @ 50Mhz Clk
signal I_rxCont : STD_LOGIC := '1';
Pins that not needed to be assigned (monitor and debug purpose):
If you want to assign, you can assign to for example like LED respectively.
O_txRdy
O_rxSig
O_rxFrameError
D_rxClk
D_rxState
D_txClk
D_txState
Sheng
ShengN_Intel
Hi Tex,
Do you need any further help on this thread?
Sheng
Tex
thanks for the help
no more questions regarding this thread
thank you
regards
Tex
