17124 Discussions
USB Blaster Fix Hardware Port Number
Alvin_00
Hi all,
I'm having issue when connecting Multiple USB Blaster to a single PC.  I'm writing to script to automatically program my FPGA using theses USB Blasters.
The issue is when I disconnect any of them then the hardware port name will change incrementally.
Example:
Initial Stage
Blaster 1 -- USB Blaster [USB-2]
Blaster 2 -- USB Blaster [USB-3]
Blaster 3 -- USB Blaster [USB-4]
When I disconnect and reconnect example Blaster 3. It seems that the blaster driver is being reinstall then it became like below.
Blaster 3 -- USB Blaster [USB-5]
This causes an issue when I'm trying to program using Blaster 3 which the port number was off.
Does anyone know how to fix the value of the port number?
YuanLi_S_Intel
The value is not fixed. It is not working in that way.
