17249 Discussions
USB Blaster II not recognized in CentOS 7
Hello there,
I am having an issue regarding the Max 10 Development Kit where I installed the drivers and set it up according to this url: "https://www.altera.com/support/support-resources/download/drivers/dri-usb_b-lnx.html
Thus my setup looks like this:
# USB-Blaster
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6002", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6003", MODE="0666"
# USB-Blaster II
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6010", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6810", MODE="0666"
I have another version installed on another computer with CentOS Linux release 6.4 that is working (with same configuration).
The new configuration I am running on is CentOS Linux release 7.3.1611 (Core).
Any ideas?
--- Quote Start ---
Hello there,
# USB-Blaster
# USB-Blaster II
Any ideas?
--- Quote End ---
Did you ever resolve this issue? Or is there someone else who has any understanding of this problem?
Thanks!
--- Quote Start ---
Hello there,
# USB-Blaster
# USB-Blaster II
Any ideas?
--- Quote End ---
Did you happen to figure this out? Does anyone else have any idea on what could be going wrong here? I'm currently dealing with the same issue.
--- Quote Start ---
--- Quote End ---
Hello there,
There was some problem with the permissions and acess to the USB interface. The strange thing here is that for some reason the interface started to function normally after a day or so.
I think I needed to restart the computer (the problem here is that it was a laboratory computer that I did not had root access).
After a while it started to work properly, but then, I did not no what could have triggered this errors.
