17254 Discussions
USB-Blaster: Unable to read device chain - JTAG chain broken
I'm using Ubuntu14.04 and quartus14.1. When I run jtagconfig, I get:
$ jtagconfig
1) USB-Blaster [3-6]
The hardware is correct because I can read the JTAG chain using a old PC.
Some extra information:
$ cat /etc/udev/rules.d/51-usbblaster.rules# USB-Blaster# # from http://www.fpga-dev.com/altera-usb-blaster-with-ubuntu/# For Altera USB-Blaster permissions.
SUBSYSTEM=="usb",
ENV{DEVTYPE}=="usb_device",
ATTR{idVendor}=="09fb",
ATTR{idProduct}=="6001",
MODE="0666",
NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}",
RUN+="/bin/chmod 0666 %c"
$ ls -l /etc/jtagd/pgm_parts.txt
-rw-r--r-- 1 root root 921110 Jan 12 12:54 /etc/jtagd/pgm_parts.txt
I have also re-run:
$ sudo udevadm control --reload
But nothing help!
Any tips?
I find the issue: The USB-blaster must first be powered from the board and then connected to the PC.
So the procedure step by step:
- connect the USB-Blaster to your board
- power-on the board
- plug the USB cable in the PC
Doing so, jtagconfig is working:
$ jtagconfig
4BA00477 SOCVHPS
02D120DD 5CSE(BA5|MA5)/5CSTFD5D5/..
Well, even following this procedure doesn't work 100%.
It's look like running quartus_hps first help jtagconfig working:
$ quartus_hps -c1 -o PV -a 0x0 -s 262144 ./preloader-mkpimage.bin
The conditions to make jtagconfig working are not clear to me.
Charly78,
I had same problem. Followed Andy1666's code in the following post:
http://ubuntuforums.org/showthread.php?t=1441742
Seems to have worked for me. I have no idea why.
Charly78,
Disregard previous. It is not working after all. Not only that, Quartus keeps crashing. Believe the Ubutu machine is going back to System 76, and I'm going back to Windows.
OK, found something that really works (I think). See USB-Blaster section on the following:
https://wiki.archlinux.org/index.php/altera_design_software#usb-blaster_download_cable_driver
I've undone all previous attempts, made the changes listed in the arch wiki, and was able to program arrow SoCKit. Using Ubuntu 14.10.
For now, it's working. Will post more if I run into problems again.
LLelo1
The link posted above (https://wiki.archlinux.org/index.php/altera_design_software#usb-blaster_download_cable_driver) does not work anymore, would it be possible to get the details?
I am having the exact same problem where jtagconfig would work randomly. I tried different solution that I found online but none of them seems to work systematically.
Ludovic
SThor8
Hi
I have had the same problem on Ubuntu 18.04 but got it working
Try to enter this in a terminal window
killall jtagd jtagd --user-start
Then my jtagconfig return this
intelFPGA/18.1/quartus/bin/jtagconfig 1) USB-Blaster [1-5] 031050DD 10M50DA(.|ES)/10M50DC
Wait 10 seconds before you try to program the FPGA so the restart takes effect.
Beside creating the rule (as i guess you have done) /etc/udev/rules.d/51-usbblaster.rules
I also did
sudo apt-get install libudev-dev
But I am not sure if that was necessary
Note that you have to redo
Every time it loose connection, this is noway a good solution but at least you can now program it
jobonono
Hi @SThor8
I tried implementing your solution on my Ubuntu 20.04 machine, but I get an
Command 'jtagd' not found
error.
Any suggestions on what to do?
I can get the USB-blaster to work  very sporadically, fiddling with plugging the usb cable in/out of the pc and powering the FPGA on/off
SThor8
I do nto have the 'jtagd' command either but 'killall jtagd' works
I do not know why it is so
hxj141
You have to run it from the file locally. First cd into the directory where you have Quartus installed and then to go to {whatever version number it is}/quartus/bin.
Check if the jtagd file is there with the command ls, and if it is, simply do the command he posted above but with ./jtagd in the front instead of just jtagd. This'll execute the file as if it was a command
CUAlex
All of the above solutions do not seem to be working. My error message alternates between JTAG chain broken, and Port Permissions Denied.
HalmonCelman
if anyone encountered same problem, for me worked ( i'm using Ubuntu 20.4 and Quartus Prime Lite 21.1 )
->create new file in etc/udev/rules.d named 51-usbblaster.rules  ( for me worked: sudo gedit 51-usbblaster.rules)
->copy this:
# USB Blaster
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6002", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6003", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
# USB Blaster II
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6010", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6810", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
paste to file 51-usbblaster.rules , save and restart your computer
->if you don't have, install:
sudo apt-get install libxext6:i386
sudo apt-get install libxtst6:i386
sudo apt-get install libxi6:i386
->and install 32-bits version of libudev library
sudo apt-get install libudev1:i386
sudo ln -sf /lib/x86_64-linux-gnu/libudev.so.1 /lib/x86_64-linux-gnu/libudev.so.0
then it should work( for me it works )
Hope it helps someone.
Regrads
Halmon Celman
rthomp
My problem stemmed from UDEV rules. Below are my steps to circumvent the issue.
Only need to do once
Copy the following into /etc/udev/rules.d/92-usbblaster.rules simply copy the attached rules as /etc/udev/rules.d/92-usbblaster.rules
# For Altera USB-Blaster permissions:
# USB-Blaster
SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", MODE="0666", GROUP="plugdev"
SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6002", MODE="0666", GROUP="plugdev"
SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6003", MODE="0666", GROUP="plugdev"
# USB-Blaster II
SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6010", MODE="0666", GROUP="plugdev"
SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6810", MODE="0666", GROUP="plugdev"
(I read that 92 mattered somewhere as it needed to be larger than one of the other rule numbers. I understand that Intel claims 51 should be sufficient. Please correct me here if someone knows more about this.)
You will have to do this again when necessary
1. Run service udev restart
2. Replug in all associated USB devices.
          After a few retries, I realized the USB-C adapter
          needed to be reinserted along with the the USB Blaster
Pouya1
I have the same problem for an Intel Stratix 10 MX FPGA installed in a workstation. The board is powered up using an 8-pin AUX connector (in addition to pcie slot). I'm running Ubuntu 18.04 LTS. A couple of days ago, when I was running jtagconfig everything worked perfectly (I could see the device name and jtag chain was also correct). But after a few days (I didnt touch anything or any commands or even I didnt program the fpga) when I entered the same command, jtag chain was broken:
1) Intel Stratix 10 MX FPGA Development Kit [1-14]
I tried all suggestions here in this forum, but none was helpful. I would appreciate it if you could help me with this.
Thank you!
