USB Blaster remote setup
I'm trying to remotely connect to the jtag server to program a DE-5 board.
Netstat in the server shows me this
tcp 0 0 *:1309 *:* LISTEN
But when I run the
jtagconfig --addserver server_name password
in the local machine
it prompts nothing but when I run jtagconfig later, it shows me
Remote server server_name: Unable to connect.
I ran jtag --foreground --debug
on n the local machine and got the follwing output
madushan@electron:~$ jtagd --foreground --debug
JTAG daemon started
Using config file /etc/jtagd/jtagd.conf
Remote JTAG permitted when password set
No USB device change detection because libudev.so.0 not found
Can't bind to TCP port 1309 - exiting
once again tried a telnet and result,
madushan@electron:~$ telnet server_name 1309
Trying 129.252.131.52...
Connected to server_name.
Escape character is '^]'.
Connection closed by foreign host.
I would really appreciate somebody could help me with this.
CapChimiChangas
First, you are missing libudev and libusb in your system.
Also : "Remote JTAG permitted when password set "
You need to set a password.
CapChimiChangas
One more thing if your network is secure and your lab has no external access, do the following:
AS root on the machine with access to your device, run
jtagd
then immediately
jtaconfig --enable-remote password_of_your_choice
You can now use Quartus to connect remotely and program and debug via JTAG on your device.
