17268 Discussions
Unable to find the license file. It appears that your license file environment variable (e.g., LM_L
taha3
i use Ubuntu and i download Quartus lite , and  i download license file (.dat), and
set environment by    export LM_LICENSE_FILE="path-licese-file.dat "
but it still shows this message when i run simulator waveform  ?
/home/user/intelFPGA_lite/22.1std/questa_fse/linux_x86_64//vsim -c -do ALU_4bit.do
Unable to find the license file. It appears that your license file environment variable (e.g., LM_LICENSE_FILE) is not set correctly.Unable to checkout a license. Vsim is closing.
** Error: Invalid license environment. Application closing.
can anybody help ?
AR_A_Intel
Hello
Welcome to INTEL forum. Could you kindly help check you license setup again. Starting with your OS support, whether your machine is supported or not (OS) by referring to link below:
https://www.altera.com/support/support-resources/download/os-support.html
taha3
i am using Ubuntu 22.04 LTS and its support Intel Quartus Prime Pro Edition, does it include Intel Quartus Prime Lite Edition ?
AR_A_Intel
Hi
Just dropping by to check whether you have any follow up/update from your end? Based on my understanding, it should include Intel Quartus Prime Lite Edition.
AR_A_Intel
We have not heard from you and I hope that my last note clears up this matter and it can now be move forward. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
