17253 Discussions
Unexplainable indetermination
Contributeur émérite II
1 323 Visites
i've got this undetermination 'X' and i don't understand its origin, since the function is set to Zero, their roots are zero everywhere, but this signal remains 'X' anyone can help
Code:
AntImagen2 <= Resultattmp(CONV_INTEGER(Pixelactual));
As you can see down the origin its 0 at the center reset, the signal is inicialised to 0 as the others, my code so there is no sense of this X since the code is the same as this* code in this** photo:
* AntImagen1 <= Resultattmp(CONV_INTEGER(Pixelactual)+9); -
AntImagen2 <= Resultattmp(CONV_INTEGER(Pixelactual)); --
AntImagen3 <= Resultattmp(CONV_INTEGER(Pixelactual)+11); -
http://i47.tinypic.com/22yzjk.jpg
Pixelactual is set to 12 during all the reset state so pixelactual(12) which is zero...
Resultatmp contents:
http://i50.tinypic.com/29cl5qt.jpg
Can anyone help?
Thanx
0 Compliments
2 Réponses
407 Visites
Ususally X comes when you drive the same signal from two sources.
0 Compliments
407 Visites
Solved by resetting all variables and signals Solved at second or third calculation.
0 Compliments
Répondre
