- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
i've got this undetermination 'X' and i don't understand its origin, since the function is set to Zero, their roots are zero everywhere, but this signal remains 'X' anyone can help Code: AntImagen2 <= Resultattmp(CONV_INTEGER(Pixelactual)); As you can see down the origin its 0 at the center reset, the signal is inicialised to 0 as the others, my code so there is no sense of this X since the code is the same as this* code in this** photo: * AntImagen1 <= Resultattmp(CONV_INTEGER(Pixelactual)+9); - AntImagen2 <= Resultattmp(CONV_INTEGER(Pixelactual)); -- AntImagen3 <= Resultattmp(CONV_INTEGER(Pixelactual)+11); - ** http://i47.tinypic.com/22yzjk.jpg Pixelactual is set to 12 during all the reset state so pixelactual(12) which is zero... Resultatmp contents: http://i50.tinypic.com/29cl5qt.jpg Can anyone help? ThanxLink copiato
2 Risposte
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Ususally X comes when you drive the same signal from two sources.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Solved by resetting all variables and signals Solved at second or third calculation.
Rispondere
Opzioni discussione
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
