17263 Discussions
Universal Shift register help( in structrual)
Hi everyone!
I've got an assignment about writing the VHDL code for a universal shift register(using structural), and i was given a diagram of the circuit to replicate. So far I've made this, the only errors i'm getting is when i'm trying to display the outputs.
"Multi-source in Unit <Uni_reg> on signal <Qas>; this signal is connected to multiple drivers." (i get this error for all three outputs)
(i'm fairly new to vhdl, so any tip would help)
here's the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Uni_reg is
port( LR,SP,clk,clear,shL,shR: in std_logic; -- shL = shift left shR= shift right
Da,Db,Dc : in std_logic; --inputs for load
Qa,Qb,Qc : out std_logic); --out puts from the flipflops
end Uni_reg;
architecture Structural of Uni_reg is
signal lr1,lr2,sp1,sp2,R1,R2,R3 : std_logic;
signal L1,L2,L3,LOAD1,LOAD2,LOAD3:std_logic;
signal c1,c2,c3 : std_logic;
signal Qas,Qbs,Qcs : std_logic;
component andgate
port(a,b,c : in std_logic; z : out std_logic);
end component;
component orgate
end component;
component notgate
port(a: in std_logic; z : out std_logic);
end component;
component Dflipflop
port(D,clk: in std_logic; Q: out std_logic);
end component;
begin
NOTGATE1: notgate port map (LR,lr1);--1st notgate for LEFT/RIGHT
NOTGATE2: notgate port map (lr1,lr2);--2nd notgate for LEFT/RIGHT
NOTGATE3: notgate port map (SP,sp1);--1st notgate for SERIAL/PARRALLEL
NOTGATE4: notgate port map (sp1,sp2);--2nd notgate for SERIAL/PARRALLEL
ANDGATE1: andgate port map (shR,sp2,lr2,R1); --for right shift of 1st bit
ANDGATE2: andgate port map (sp2,lr1,Qbs,L1); --for left shift of 1st bit
ANDGATE3: andgate port map (lr2,sp1,Da,LOAD1);--for load of 1st bit
ANDGATE4: andgate port map (Qas,sp2,lr2,R2); --for right shift of 2nd bit
ANDGATE5: andgate port map (sp2,lr1,Qcs,L2); --for left shift of 2nd bit
ANDGATE6: andgate port map (lr2,sp1,Db,LOAD2);--for load of 2nd bit
ANDGATE7: andgate port map (Qbs,sp2,lr2,R3); --for right 3rd bit
ANDGATE8: andgate port map (sp2,lr1,shL,L3); --for left 3rd bit
ANDGATE9: andgate port map (lr2,sp1,Dc,LOad3);--for loading 3rd bit
ORGATE1: orgate port map (R1,L1,LOAD1,c1);--for the 1st flipflop
ORGATE2: orgate port map (R2,L2,LOAD2,c2);--for the 2nd flipflop
ORGATE3: orgate port map (R3,L3,LOAD3,c3);--for the 3rd flipflop
FLIPFLOP1: Dflipflop port map (c1,clk,Qas);
FLIPFLOP2: Dflipflop port map (c2,clk,Qbs);
FLIPFLOP3: Dflipflop port map (c3,clk,Qcs);
process(clk,clear)
begin
if clear ='1' then
Qas<='0';
elsif (clk'event and clk = '1') then
Qas<=Qas;
Qa <= Qas;
end if;
end process;
process(clk,clear)
begin
if clear ='1' then
Qbs<='0';
Qbs<= Qbs;
Qb <= Qbs;
end if;
end process;
process(clk,clear)
begin
if clear ='1' then
Qcs<='0';
Qcs<=Qcs;
Qc <= Qcs;
end if;
end process;
end Structural;
Qas is driven at 2 places:
1. FLIPFLOP1: Dflipflop port map (c1,clk,Qas);
2. process(clk,clear)
begin
if clear ='1' then
qas<='0';
qas<=qas;
Qa <= Qas;
end if;
end process;
For the first statement, FLIPFLOP output driven to Qas and at the second statement, Qas is re-assigned again. This would cause multiple driver.
Maybe there is typo for statement 2?
QAs is driven both in the Dflipflop component and in a process.
FLIPFLOP1: Dflipflop port map (c1, clk, Qas); process(clk,clear) begin if clear ='1' then Qas <= '0'; elsif (clk'event and clk = '1') then Qas <= Qas; Qa <= Qas; end if; end process;
Hint: you can leave out the Dflipflop and use c1 in the process.
Oh, I see now. Thank you so much for the help,guys.
I do hope you move on from this mundane task.
Structural VHDL like this is pretty useless and utterly horrible. Please dont stick with it in future. If all your assignments are like this - complain.
