Use of megafunctions
Hello everyone,
I am a beginner in Quartus. I am trying to use the square root megafunction in Quartus. What I am doing is I have instantiated it :
mysqrt_alt_restoring_sqrt_cta mysqrt(.aclr(clear),.clken(clkenable),.clock(CLOCK_50),.rad(vz),.root_result(sqroot));
However, it gives me an error :
"mysqrt"; expecting "<=", or "="
So, I assumed that may be I need to assign the value returned by this function to some other
so i assigned the return value to x
x= mysqrt_alt_restoring_sqrt_cta mysqrt(.aclr(clear),.clken(clkenable),.clock(CLOCK_50),.rad(vz),.root_result(sqroot));
But then it still shows the error as:
near text "mysqrt"; expecting ";"
I am confused. One more thing is that I need to use the square root function for integers .
Could you guys please help me out. Could you please tell me the way the megafunction needs to be defined?:(
Thanks a lot in advance.
regards,
Sim
I guess it's a confusion of instance and component name. I suggest to use the MegaWizard generated instantiation template for a syntactical correct module instantiation example. Also the Verilog templates in Quartus editor should help to learn the correct syntax.
Generally, I think it's better to consult a Verilog text book for first HDL programming steps instead of using a trial and error method.
Thanks a lot for your reply. I will try it and go through some book and let you guys know. Thanks again.
