17259 Discussions
Use of permanently enabled tristate buffer
On an existing design, I've seen a gated clock output being buffered at the pin with a 'SOFT' buffer in series with a permanently enabled tristate buffer. As I am not familar with this arrangement, can anybody explain why this might have been tackled in this manner?
Tim
Note: The 'soft' and 'tristate' buffers in this design appear on a schematic entry diagram driving an output pin.
You get a permanently enabled tristate buffer, if a signal is defined as inout but only used as output. Quartus isues a warning to remind you, that something may have been forgotten in the design definition.
