I am a beginner, and I am looking for some advice regarding the Pinout Planner. I have created a project for the Max10 Deca board, and I have use QSYS to create a system similar to one of the example projects, with the same exported pins and such. However, when I generate this QSYS systemm include the QIP file, and go to Pin Planner, there are no pins. Am I missing a step? How do I get the pins exported from QSYS to the Pin Planner? Thank you for any advice. ngoharaLink Copied
Back to the Quartus IDE ( assuming that you've placed the Qsys module in a schematic ), had you performed the "update symbol" operation for that module ?
You need to do the analysis and synthesis step before anything will show up in pin planner. The button is to the right of the compile button.
Thank you for the advice!
