17255 Discussions
Using a project as a "black box" module for other project
EugeneF
There is a large Quartus II project, consisted of a multiple bdf, verilog, VHDL files. Is it possible to compile it into some single file (verilog or VHDL or some other), and then use it as a single "black box" module for other projects, without showing its internall structure?
Nurina
This should be possible. You may find these pages useful:
https://www.intel.com/content/www/us/en/docs/programmable/683796/18-1/creating-black-boxes-to-create-netlists.html
https://www.intel.com/content/www/us/en/docs/programmable/683796/18-1/creating-black-boxes-in-verilog-hdl-81234.html
And since you are using Quartus II you should be able to create VHDL/Verilog file from .bdf file.
Does this answer your question?
Nurina
Nurina
We do not receive any response from you on the previous question/reply/answer provided. Please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
