17255 Discussions
Using of Restrict keyword
Hi All,
We have implemented 4 kernels in one .cl file. We are trying to optimize the kernels. So gone through AOCL best practices guide, it suggests the usage of restrict keyword in pointer arguments whenever possible. So we have used for all 4 kernels. But resource utilization has increased from 58% to 135%. Instead, if we use for one kernel, then it is giving performance (kernel execution time is decreased from 98msec to 50msec). Is there any alternative for restrict keyword?
Restrict should not increase resource usage that much unless without restrict, you get fully sequential operation, while with restrict you get pipelined operation with a high II which then requires extra resources to buffer data and accommodate the high II. Can you post your kernel area report before and after adding restrict?
Please find the below resource utilisation numbers with and without restrict
With Restrict
Family : Arria 10
Device : 10AX115H3F34E2SG
Timing Models : Final
Logic utilization (in ALMs) : 258,918 / 427,200 ( 61 % )
Total registers : 456008
Total pins : 155 / 618 ( 25 % )
Total virtual pins : 0
Total block memory bits : 19,882,664 / 55,562,240 ( 36 % )
Total RAM Blocks : 2,312 / 2,713 ( 85 % )
Total DSP Blocks : 192 / 1,518 ( 13 % )
Total HSSI RX channels : 4 / 24 ( 17 % )
Total HSSI TX channels : 4 / 24 ( 17 % )
Total PLLs : 30 / 80 ( 38 % )
Without Restrict
Family : Arria 10
Logic utilization (in ALMs) : 249,039 / 427,200 ( 58 % )
Total registers : 453705
Total block memory bits : 12,301,448 / 55,562,240 ( 22 % )
Total RAM Blocks : 1,755 / 2,713 ( 65 % )
I was talking about the compiler's resource estimation report which includes the loop analysis and line-by-line estimated area usage and shows the estimated area usage is going to increase from "58% to 135%".
The post-place-and-route area utilization is not much different in your case anyway.
