17261 Discussions
Using 'set_clock_groups' without parameter -asynchronous or -exclusive?
From the Quartus user manual "Quartus II Handbook Version 9.1 Volume 3: Verification":
set_clock_groups
[-asynchronous | -exclusive]
-group <clock name>
[-group <clock name>]
[-group <clock name>] ...
a group is defined with the -group option. the timequest timing analyzer cuts the
timing paths between clocks each of the separate -groups groups.
I tried to use following constrain in SDC file:
set_clock_groups
-group [get_clocks {CLK_A}]
-group [get_clocks {CLK_B}]
But TimeQuest still reports violation of paths between
domain CLK_A and CLK_B.
Am I miss-understanding something???
# . PS: NO violation is reported if I use:
set_clock_groups -asynchronous
OR
set_clock_groups -exclusive
Looks like an issue with the documentation then. It should indeed be set_clock_groups -asynchronous to specify that the clocks are unrelated. Leaving out the -asynchronous or -exclusive actually tells Timequest that the domains _are_ related.
Ben
Strange. When I run it without those options I get an error:
At least one of the following options are required: -asynchronous, -exclusive
Are you sure you're not seeing this? Regardless, you need one of those options for that command.
Hi Rysc,
You are right!
My wrong that forget to check the log first,
thanks.
--- Quote Start ---
--- Quote End ---
