I am wondering how and when the pre-computed CRC that gets loaded into the fpga CRC-correction block gets generated. I am able to get the CRC from both internal logic and by using the JAM player using CHANGE_EDREG, but am unable to find it when i inpect the .sof or .pof files that are generated by Quartus Prime. The link below indicates that the crc is precomputed by Quartus Prime, so it must be hiding somewhere in the programming files. Is this correct?
We are trying to find a way to check if the .pof that is loaded onto the fpga matches the .pof file that is stored on the host controller using the pre-computed CRC. If this is not possible, what is the best way to check if the .pof that is loaded into the flash of the fpga matches the .pof on the host controller without reflashing the fpga?
Thanks for looking into this for me.
-David
Apologize for the delay in response.
Per my understanding, you wanted to know if the .pof loaded into the FPGA is correct or not, right? For that, you may check the CRC. If there is no error at the CRC, meaning the .pof loaded is correct.
Aiman
Aiman,
That is not quite our goal.
We want to be able to check to see if the .pof on the FPGA matches the .pof that we have on the host controller so that we can quickly check that the fpga has the latest image without flashing a new image to the FPGA flash. We were hoping to use the CRC to accomplish this and want to know if there is a way to extract the pre-computed CRC from the .pof file?
We are using the Jam STAPL byte-code player to flash the fpga which is quite slow, so we want to update the fpga as little as possible.
David
What is the nconfig, conf_done, nstatus signal? Does the conf_done goes high?
Aiman
Any update for this case?
Aiman
Do you still need further assistance for this case?
Aiman
- As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘ https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
