17263 Discussions
Using the SDRAM Controller with Qsys
I am trying to use Eclipse to program an application using the lcd. My qsys system uses an sdram controller. I receive a single error in the alt_main.c which was generated in the bsp.
The error states undefined reference to main. It occurs in the return line of the code
extern int main (int, char **, char **);
void alt_main (void)
#ifndef ALT_NO_EXIT
int result;
# endif
/* ALT LOG - please see HAL/sys/alt_log_printf.h for details */
ALT_LOG_PRINT_BOOT("[alt_main.c] Entering alt_main, calling alt_irq_init.\r\n");
/* Initialize the interrupt controller. */
alt_irq_init (NULL);
/* Initialize the operating system */
ALT_LOG_PRINT_BOOT("[alt_main.c] Done alt_irq_init, calling alt_os_init.\r\n");
ALT_OS_INIT();
* Initialize the semaphore used to control access to the file descriptor
* list.
ALT_LOG_PRINT_BOOT("[alt_main.c] Done OS init, calling alt_sem_create.\r\n");
ALT_SEM_CREATE (&alt_fd_list_lock, 1);
/* Initialize the device drivers/software components. */
ALT_LOG_PRINT_BOOT("[alt_main.c] Calling alt_sys_init.\r\n");
alt_sys_init();
ALT_LOG_PRINT_BOOT("[alt_main.c] Done alt_sys_init.\r\n");
#if !defined(ALT_USE_DIRECT_DRIVERS) && (defined(ALT_STDIN_PRESENT) || defined(ALT_STDOUT_PRESENT) || defined(ALT_STDERR_PRESENT))
* Redirect stdio to the apropriate devices now that the devices have
* been initialized. This is only done if the user has requested these
* devices be present (not equal to /dev/null) and if direct drivers
* aren't being used.
ALT_LOG_PRINT_BOOT("[alt_main.c] Redirecting IO.\r\n");
alt_io_redirect(ALT_STDOUT, ALT_STDIN, ALT_STDERR);
#endif
#ifndef ALT_NO_C_PLUS_PLUS
* Call the C++ constructors
ALT_LOG_PRINT_BOOT("[alt_main.c] Calling C++ constructors.\r\n");
_do_ctors ();
#endif/* ALT_NO_C_PLUS_PLUS */
#if !defined(ALT_NO_C_PLUS_PLUS) && !defined(ALT_NO_CLEAN_EXIT) && !defined(ALT_NO_EXIT)
* Set the C++ destructors to be called at system shutdown. This is only done
* if a clean exit has been requested (i.e. the exit() function has not been
* redefined as _exit()). This is in the interest of reducing code footprint,
* in that the atexit() overhead is removed when it's not needed.
ALT_LOG_PRINT_BOOT("[alt_main.c] Calling atexit.\r\n");
atexit (_do_dtors);
#endif
* Finally, call main(). The return code is then passed to a subsequent
* call to exit() unless the application is never supposed to exit.
ALT_LOG_PRINT_BOOT("[alt_main.c] Calling main.\r\n");
#ifdef ALT_NO_EXIT
main (alt_argc, alt_argv, alt_envp);
#else
result = main (alt_argc, alt_argv, alt_envp);
close(STDOUT_FILENO);
exit (result);
#endif
ALT_LOG_PRINT_BOOT("[alt_main.c] After main - we should not be here?.\r\n");
This error does not occur when using on-chip memory, however that won't be sufficient for the project according to eclipse.
How should I approach fixing the error?
It seems that the problem isn't the SDRAM controller,
Rather, make sure that the c file containing your "main" is correctly
added to your project.
Check the following line in the Makefile of your project :
# Paths to C, C++, and assembly source files.
C_SRCS := ...
regards,
Hello all,
This code has been tested with the BeMicroMax and it will be help you to test your SDRAM memory :
We assume that you are set your memory controller with QSYS :
In my case the memory controller is mapped at the address : (0x800000)# define SDRAM_BASE (0x800000)# define SDRAM_BASE_MUX (SDRAM_BASE + 0x2000) /** Offset for the exception */
/** Variables */
uint32_t u32AddrSram = 0;
uint16_t u16Value = 0;
uint16_t u16ReadSramValue = 0;
/** example for write and read only one byte at the time in the sram */
for( u32AddrSram = 0; u32AddrSram< 100 ; u32addrsram += 0x08
/** Write Data */
alt_printf("\n*** SDRAM WRITE[%x] VALUE = %x \n\r ", (SDRAM_BASE_MUX + u32AddrSram) , (uint8_t)(u16Value));
iowr_8direct(SDRAM_BASE_MUX, (uint16_t)u32AddrSram, (uint8_t)u16Value);
/** Read Data */
u16ReadSramValue = iord_8direct(SDRAM_BASE_MUX, u32AddrSram);
alt_printf("\n*** SDRAM READ[%x] VALUE = %x \n\r ", (SDRAM_BASE_MUX + u32AddrSram), u16ReadSramValue);
/** Change the value */
u16Value++;
/** example for write and read only 2bytes at the time in the sram */
u16Value = 0xA000;
for( u32AddrSram = 0; u32AddrSram< 100 ; u32addrsram += 0x10
/** Write Data */
alt_printf("\n*** SDRAM WRITE[%x] VALUE = %x \n\r ", (SDRAM_BASE_MUX + u32AddrSram) , (uint16_t)(u16Value));
iowr_16direct(SDRAM_BASE_MUX, (uint16_t)u32AddrSram, (uint16_t)u16Value);
/** Read Data */
u16ReadSramValue = iord_16direct(SDRAM_BASE_MUX, u32AddrSram);
u16Value++;
/*** Result for Byte */
*** SDRAM WRITE[802000] VALUE = 0
*** SDRAM READ[802000] VALUE = 0
*** SDRAM WRITE[802008] VALUE = 1
*** SDRAM READ[802008] VALUE = 1
*** SDRAM WRITE[802010] VALUE = 2
*** SDRAM READ[802010] VALUE = 2
*** SDRAM WRITE[802018] VALUE = 3
*** SDRAM READ[802018] VALUE = 3
*** SDRAM WRITE[802020] VALUE = 4
*** SDRAM READ[802020] VALUE = 4
*** SDRAM WRITE[802028] VALUE = 5
*** SDRAM READ[802028] VALUE = 5
*** SDRAM WRITE[802030] VALUE = 6
*** SDRAM READ[802030] VALUE = 6
*** SDRAM WRITE[802038] VALUE = 7
*** SDRAM READ[802038] VALUE = 7
*** SDRAM WRITE[802040] VALUE = 8
*** SDRAM READ[802040] VALUE = 8
*** SDRAM WRITE[802048] VALUE = 9
*** SDRAM READ[802048] VALUE = 9
*** SDRAM WRITE[802050] VALUE = a
*** SDRAM READ[802050] VALUE = a
*** SDRAM WRITE[802058] VALUE = b
*** SDRAM READ[802058] VALUE = b
*** SDRAM WRITE[802060] VALUE = c
*** SDRAM READ[802060] VALUE = c
/** result for 2bytes read */
*** SDRAM WRITE[802000] VALUE = a000
*** SDRAM READ[802000] VALUE = a000
*** SDRAM WRITE[802010] VALUE = a001
*** SDRAM READ[802010] VALUE = a001
*** SDRAM WRITE[802020] VALUE = a002
*** SDRAM READ[802020] VALUE = a002
*** SDRAM WRITE[802030] VALUE = a003
*** SDRAM READ[802030] VALUE = a003
*** SDRAM WRITE[802040] VALUE = a004
*** SDRAM READ[802040] VALUE = a004
*** SDRAM WRITE[802050] VALUE = a005
*** SDRAM READ[802050] VALUE = a005
*** SDRAM WRITE[802060] VALUE = a006
*** SDRAM READ[802060] VALUE = a006
