17264 Discussions
Using two ethernet blaster II from one computer
HTork
Hi!
I have to systems each containing an Intel Cyclone II fpga.
I want to have one ethernet blaster II connected to each of them.
These are the two blasters. IP address removed.
bash-3.1$ jtagconfig
1) EthernetBlasterII on aceb077a.XXX.yyy [EthernetBlasterII]
020B30DD EP2C15/20
2) EthernetBlasterII on aceb1350.XXX.yyy [EthernetBlasterII]
Unable to read device chain (JTAG chain broken)
If I do:
nios2-download --cable="EthernetBlasterII on aceb077a.XXX.yyy [EthernetBlasterII]" --device=1 --instance=0 --go --reset-target --accept-bad-sysid SOPCsystem/software/test_software/test_software.elf & nios2-terminal
I get the following error message:
[1] 42800
nios2-terminal: You have more than one JTAG cable available so you must use the
nios2-terminal: --cable option to choose between them (or set up a cable from
nios2-terminal: the launch configuration window).
nios2-terminal: No --cable option was provided (or you selected Automatic)
bash-3.1$ jtagconfig -Using cable "EthernetBlasterII on aceb077a.XXX.yyy [EthernetBlasterII]", device 1, instance 0x00
-Resetting and pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloaded 67KB in 3.9s (17.1KB/s)
Verified OK
Starting processor at address 0x04000194
And then everything hangs. Every time!
But if I remove cable 2 by writing:
jtagconfig --remove 2
Then nios2-download  works without perfectly.
Why is this so?
Absolutely no help from reading the manuals.
nios2-download --help provides the following non accurate description:
 -c/--cable <cable name> Specifies which JTAG cable to use (not needed if
you only have one cable).
EricMunYew_C_Intel
You can launch two programmers for the two ethernet blaster ii.
