17261 Discussions
VHDL Error. Type of identifier does not agree with it's usage
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std;
entity multi_main_file is
port(
Clock,reset: in std_logic
end multi_main_file;
architecture beh of multi_main_file is
component pc_adder_mul is
port(
add_in: in std_logic_vector(31 downto 0);
control: in std_logic;
add_out: out std_logic_vector(31 downto 0)
end component;
component and1 is
port(
and_in1: in std_logic;
and_in2: in std_logic;
and_out: out std_logic
end component;
component alu_control is
port (
instr_5_0: in STD_LOGIC_VECTOR (5 downto 0);
alu_op: in STD_LOGIC_VECTOR (1 downto 0);
alu_control_out: out STD_LOGIC_VECTOR (2 downto 0)
end component;
component control_unit is
port(
Instruction: in std_logic_vector(5 downto 0);
Reg_Dest: out std_logic;
Branch: out std_logic;
MemRead: out std_logic;
MemToReg: out std_logic;
ALUOp: out std_logic_vector(1 downto 0);
MemWrite: out std_logic;
ALUSrc: out std_logic;
RegWrite:out std_logic
--Jum: out std_logic;
end component;
component data_memory is
port(
MemWrite: in std_logic;
MemRead: in std_logic;
Clock: in std_logic;
address:in std_logic_vector(31 downto 0);
Write_Data: in std_logic_vector(31 downto 0);
Read_Data: out std_logic_vector(31 downto 0)
end component;
component instruction_memory is
port(
Instruction_Addr: in std_logic_vector(31 downto 0);
Instruction: out std_logic_vector(31 downto 0)
end component;
component alu is
port(
A: in std_logic_vector(31 downto 0);
B: in STD_LOGIC_VECTOR(31 downto 0);
alu_control: in STD_LOGIC_VECTOR(2 downto 0);
result: out STD_LOGIC_VECTOR(31 downto 0);
zero_flag: out STD_LOGIC
end component;
component program_counter is
port(
PC_in: in std_logic_vector(31 downto 0);
PC_out: out std_logic_vector(31 downto 0)
end component;
component register_file is
generic(
Data_width:integer:=32;
Address_width:integer:=5
port(
Read_Reg_1: in std_logic_vector(Address_width-1 downto 0);
Read_Reg_2: in std_logic_vector(Address_width-1 downto 0);
Write_Reg: in std_logic_vector(Address_width-1 downto 0);
Write_Data: in std_logic_vector(Data_width-1 downto 0);
Read_Data_1: out std_logic_vector(Data_width-1 downto 0);
Read_Data_2: out std_logic_vector(Data_width-1 downto 0);
Mem_Write: in std_logic;
Clock: in std_logic
end component;
component shift_left_module is
port (
l_sh_in: in STD_LOGIC_VECTOR (31 downto 0);
l_sh_out: out STD_LOGIC_VECTOR (31 downto 0)
end component;
component sign_extender is
port(
exten_in: in STD_LOGIC_VECTOR (15 downto 0);
exten_out: out STD_LOGIC_VECTOR (31 downto 0)
end component;
component adder1 is
port(
Add_in1: in std_logic_vector(31 downto 0);
Add_in2: in std_logic_vector(31 downto 0);
Add_out: out std_logic_vector(31 downto 0)
end component;
component mux_32 is
port (
in2: in STD_LOGIC_VECTOR(31 downto 0);
mux_select: in STD_LOGIC;
mux_out: out STD_LOGIC_VECTOR(31 downto 0)
end component;
component mux_5 is
port (
in1: in std_logic_vector(4 downto 0);
in2: in STD_LOGIC_VECTOR(4 downto 0);
mux_out: out STD_LOGIC_VECTOR(4 downto 0)
end component;
component mux_alu is
port (
in3: in std_logic_vector(31 downto 0);
mux_select: in STD_LOGIC_vector(1 downto 0);
end component;
component or1 is
port(
in1: in std_logic;
in2: in std_logic;
out1: out std_logic
end component;
component mem_data_reg is
port(
clock: in std_logic;
out1: out std_logic_vector(31 downto 0);
end component;
component shift_left_26 is
port (
l_sh_in: in STD_LOGIC_VECTOR (25 downto 0);
l_sh_out: out STD_LOGIC_VECTOR (27 downto 0)
end component;
component instr_mem is
port (
datain: in STD_LOGIC_VECTOR (31 downto 0);
irwrite: in STD_LOGIC;
irout: out std_logic_vector(31 downto 0)
end component;
component tempreg is
port (
datain :in std_logic_vector(31 downto 0);
clk :in std_logic;
dataout out std_logic_vector(31 downto 0);
end component;
component mux_aluop is
port (
in2: in std_logic;
in4: in std_logic_vector(31 downto 0);
end component;
signal s0,s1,s2,s3,s4,s5,s6,s8,s9,s10,s11,s12,s13,s14,s15,s17,s18: std_logic_vector(31 downto 0);
signal s16: std_LOGIC_VECTOR (31 downto 0);
signal c1,c2,c3,c4,c5,c6,c7,c8,c9,c10,c14,c15,c16: std_logic;
signal d1: std_logic_vector(4 downto 0);
signal c11,c12,c13: std_logic_vector(1 downto 0);
signal c17:std_logic_vector(3 downto 0);
signal w1: std_logic_vector(27 downto 0);
begin
s18(27 downto 0) <= w1(27 downto 0);
s18(31 downto 28) <= s1(31 downto 28);
mul1: pc_adder_mul port map(s0,c15,s1);
mul2: mux_32 port map(s1,s16,c3,s2);
mul3: data_memory port map(c5,c4,clock,s2,s13,s3);
mul4: instr_mem port map (s3,c7,s5);
mul5: mem_data_reg port map(clock,s3,s4);
mul6: register_file port map(s5(25 downto 21),s5(20 downto 16),d1,s8,s11,s10,c9,clock);
mul7: mux_5 port map(c8,s5(15 downto 0), s5(20 downto 16),d1);
mul8: mux_32 port map(s4,s16,c6,s8);
mul9: sign_extender port map(s5(15 downto 0),s9);
mul10: shift_left_module port map(s9,s17);
mul11: tempreg port map(s11,clock,s12);
mul12: tempreg port map(s10,clock,s13);
mul13: shift_left_26 port map(s5(25 downto 0),s18);
mul14: mux_32 port map(s12,s1,c10,s6);
mul15: mux_alu port map(s13,s9,s17,c11,s14);
mul16: alu_control port map(s5(5 downto 0),c17,c12);
mul17: alu port map(s6,s14,c17,s15,c16);
mul18: tempreg port map(s15,clock,s16);
mul19: mux_aluop port map(s15,s16,s18,c13,s0);
end beh;
mul19: mux_aluop port map(s15,s16,s18,c13,s0); error at s16.
it says type of identifier doesnot agree with it's usage.
thanks in advance. help appreciated !
Could you describe the problem you have? Just posting code (use code tags next time) and a question in the title makes it difficult to help you. Also, use descriptive names for signals. w17 does not help in debugging.
Thanks for the quick reply. I am implementing mips multi-cycle processor so it requires alot of signals. That's why I've use character with numbers. Secondly the problem is this that when I compile the code, the error says: The type of identifier "s16" does not agree with it's usage as "std_logic" type
what are the types of the ports on mux_aluop? and what types do you map onto that?
--mux32bit
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity mux_aluop is
port (
in2: in std_LOGIC_VECTOR(31 downto 0);
end mux_aluop;
architecture behave of mux_aluop is
begin
process(mux_select)
begin
if mux_select = "00" then
mux_out<=in1;
elsif mux_select = "01" then
mux_out<=in2;
elsif mux_select = "10" then
mux_out<=in3;
end if;
end process;
end behave;
I have seen the code (start using code tags), but try to answer the question in a sentence, with words, not wit code. what would you answer?
[edit] I did not see that part, but try to compare that code to the one in the other (I guess file) you copied here. What is different?
mux_aluop is a multiplexer designed which is 4x1 mux. The input and the output both have std_logic_vector
and what does your code specify them to be? (at all places)
I have basically done port mapping. The input and output provided in mux_aluop is the same as in the main file. Their types are same but still I can't figure it out where is the error .
are you sure the types are the same in the entity declaration, the component declaration and the component instantiation?
Thanks Man! the problem has been solved ! but another one popped out. I will let you know another one if you could help me ?
sure, what is the problem
