17268 Discussions
VHDL-Generics appeareing as "#define" in system.h
is there a way to propagate hardwareparameters of Avalon-Components to system.h
SOPC-Builder provides possibility to set values of generics, used in component's top level VHDL-files during instantiation of compoents.
How can the value, chosen within SOPC-Builder be propagated to e.g. system.h?
For my current projects i always have to make sure, that chosen generics match '#defines' for software projects.
THX
Josef
Did you ever get this to work? I would like to be able to do this.
Rich
I realised I was trying to do something a bit different to the just getting a generic because my generic was set-able by the user.
The answer to my problem was to edit the hw.tcl file with the following
set_module_assignment embeddedsw.CMacro.TX_ARBITERLOCK [get_parameter_property allow_tx_arbiterlock HDL_PARAMETER]
set_module_assignment embeddedsw.CMacro.RX_ARBITERLOCK [get_parameter_property allow_rx_arbiterlock HDL_PARAMETER]
Hope this helps someone one day,
Rich
ok, all that did was say whether the items were HDL parameters. I needed to add a validation callback in the tcl file e.g.
set_module_property VALIDATION_CALLBACK validate
then at the bottom define the function
proc validate {} {
set_module_assignment embeddedsw.CMacro.TX_ARBITERLOCK [get_parameter_value allow_tx_arbiterlock]
set_module_assignment embeddedsw.CMacro.RX_ARBITERLOCK [get_parameter_value allow_rx_arbiterlock]
which does seem to work
