Hello. I'm a VHDL newbie and request help on coding a counter. I'm trying to synchronize a BTRIG signal to the system clock and then toggle a short_long_sample_q signal every 4 synchronized BTRIG pulses. Here's the applicable section of code:
process ( SYS_CLK ) begin if rising_edge ( SYS_CLK ) then temp_pulse <= BTRIG ; btrig_synched <= temp_pulse ; end if ; end process ; process ( btrig_synched ) begin if rising_edge ( btrig_synched ) then btrig_counter <= btrig_counter + 1 ; end if ; end process ; process ( btrig_counter , short_long_sample_q ) begin if btrig_counter = "11" then short_long_sample_q <= not short_long_sample_q ; end if ; end process ; I don't get any compile errors but the tested behavior shows that short_long_sample_q does not consistently toggle every 4 BTRIGs. Is there a better way of coding this? Thanks.Link Copied
Hello
In your code the process controlling short_long_sample_q is asynchronous, which means that it will keep toggling this signal until btrig_counter is different than "11". This is possibly why you are experiencing strange behaviors. Make sure that SYSCLK > 2*BTRIG or else you will not be able to detect a rising edge on this signal I didn't test this code, but you can give it a try:process ( SYS_CLK )
begin
if (btrig_previous = '0') and (BTRIG = '1') then -- Rising edge detected
if (btrig_counter = "11") then -- Fourth rising edge detected
short_long_sample_q <= not short_long_sample_q;
btrig_counter <= "00";
else
btrig_counter <= btrig_counter + 1;
end if
end if
btrig_previous <= BTRIG;
end if
end process
For the next time, please post your code in code tags. This makes it easier to read.
begin
end if ;
end process ;
begin
end if ;
end process ;
it is better to have synchronus counter with sys_clk and btrig_synch as synchonous load signal process ( SYS_CLK )
begin
end if ;
end process ;
begin
end if ;
end process ;
and in the pair you can try better to make Pulse-Out generator . You simply get it. But yes do some arrangment in frequency until you get "0".
