17268 Discussions
VHDL Partially Initialize in 0 a vector array
Im trying to create an array of vectors like shown in the code below:
type ram256 is array (0 to 255) of std_logic_vector (11 downto 0);
signal memoria: ram256;
The problem is that, initially i only use about the first 25 vectors of the type. I need the other ones to be 0 but since they're 256 vectors in total, its too long to do it manually. Can anyone help me how to do it? I tried with for loop but when i use the test bench after, it seems like the memory its full of U's.
Thank you very much in advance.
You can initialize all bits using
signal memoria: ram256 := (others => (others '0'));
You can use a similar statement at the beginning of a process to set the default state and then over-ride bits.
Cheers,
Dave
--- Quote Start ---
Cheers,
Dave
--- Quote End ---
THANK YOUU! it worked :)
