VHDL Slot Machine
I am trying to make a program on a DE-1 board. It is a slot machine. The board will use 3 buttons. One for manual stopping numbers, one for automatically stopping all the numbers, and one to reset. The autostop portion will use a random number generator. I have no idea what is going wrong with this and I know there is a lot. Can somebody help? I attached my entire vhd file. It is also right here:
Library ieee;
use ieee.std_logic_1164.ALL;
use ieee.std_logic_arith.ALL;
use ieee.math_real.ALL;
entity project is
port ( manualStop, autoStop, reset, clock : in std_logic;
ssd3, ssd2, ssd1, ssd0 : out std_logic_vector(0 to 6));
end project;
architecture arch of project is
type display is array(0 to 9) of std_logic_vector(0 to 6);
constant displayMap: display := ("0000001", "1001111", "0010010", "0000110",
"1001100", "0100100", "0100000", "0001111", "0000000", "0000100");
type display2 is array(0 to 3) of std_logic_vector(0 to 6);
constant winDisplay: display2 := ("0000110", "1001111", "0001001", "0001000");
constant loseDisplay: display2 := ("1110001", "0000001", "0100100", "0110000");
signal slowClock : std_logic := '0';
begin
process(clock)
variable counter : integer := 0;
begin
if rising_edge(clock) then
if (counter = 200000) then --24Mhz/60hz/2
slowClock <= not slowClock;
counter := 0;
else
counter := counter + 1;
end if;
end if;
end process;
process(slowClock)
variable spin1 : integer := 1;
variable spin2 : integer := 1;
variable spin3 : integer := 1;
variable spin4 : integer := 1;
variable fini**** : integer := 0;
variable value1 : integer := 0;
variable value2 : integer := 2;
variable value3 : integer := 3;
variable value4 : integer := 6;
variable rand: real;
variable s1 : positive := 1;
variable s2 : positive := 1;
variable waiter: integer := 1;
begin
if (rising_edge(slowClock)) then
loop
if( spin1 = 1 ) then
value1 := ((value1 + 1) mod 9);
end if;
if( spin2 = 1 ) then
value2 := (value2 + 1) mod 9;
end if;
if( spin3 = 1 ) then
value3 := (value3 + 1) mod 9;
end if;
if( spin4 = 1 ) then
value4 := (value4 + 1) mod 9;
end if;
wait for 300 ms;
ssd3 <= displayMap(value4);
ssd2 <= displayMap(value3);
ssd1 <= displayMap(value2);
ssd0 <= displayMap(value1);
if (fini**** = 1) then
UNIFORM(s1, s2, rand);
waiter := INTEGER(TRUNC(rand*10.0));
for I in 1 to waiter loop
value1 := (value1 + 1) mod 9;
end if;
if( spin2 = 1) then
end if;
end if;
end if;
wait for 300 ms;
end loop;
if ( spin1 = 1 ) then
spin1 := 0;
elsif ( spin2 = 1 ) then
spin2 := 0;
elsif ( spin3 = 1 ) then
spin3 := 0;
elsif ( spin4 = 1 ) then
spin4 := 0;
end if;
elsif ( manualStop = '0' ) then
spin1 := 0;
spin2 := 0;
spin3 := 0;
spin4 := 0;
end if;
elsif ( autoStop = '0' ) then
fini**** := 1;
elsif ( reset = '0' ) then
spin1 := 1;
spin2 := 1;
spin3 := 1;
spin4 := 1;
fini**** := 0;
value1 := 0;
value2 := 2;
value3 := 3;
value4 := 6;
end if;
if ( spin1 = 0 ) and ( spin2 = 0 ) and ( spin3 = 0 ) and ( spin4 = 0 ) then
if ( value1 = 0 ) and ( value2 = 0 ) and ( value3 = 0 ) and ( value4 = 0 ) then
while ( reset = '1' ) loop
wait for 1000 ms;
ssd3 <= winDisplay(value4);
ssd2 <= winDisplay(value3);
ssd1 <= winDisplay(value2);
ssd0 <= winDisplay(value1);
wait for 1000 ms;
end loop;
else
wait for 1000 ms;
ssd3 <= loseDisplay(value4);
ssd2 <= loseDisplay(value3);
ssd1 <= loseDisplay(value2);
ssd0 <= loseDisplay(value1);
wait for 1000 ms;
end loop;
end if;
end if;
end loop;
end if;
end process;
end arch;
please help
What exactly is going wrong?
I assume you know you cannot synthesise this code, as it is full of all sorts of unsynthesisable bits. I assume it's a simulation only model.
Interesting , but I agree with Tricky, I think anything's possible but I would be inclined to start with an example that works on the DE-1 board in the HDL you are familiar with.
I have worked in Verilog and VHDL and for starting off ... Verilog may be easier to map to hardware ... I assume this is a design example as there are arguments for FPGA designs, Programmable controller based designs .. whatever design methodology, the Random Number Generator ( RNG ) is key and when electronics were first introduced to slot machines some governments forced vendors to still have mechanical moving parts ( wheels ) as a source of randomness. That I guess is just history now.
Alright thanks. Could someone start me out? I just need it to infinite loop at the start and increment the display numbers. I don't need buttons at all. I think I can do that myself. It is just starting out. I need to do it in VHDL. thanks.
