I have attached to this message two files that I am trying to compile (bus_relay.vhd and bcff.vhd). The problem is that the file bcff.vhd which is the top level entity will not compile. It keeps giving me an error message of (Error (10381): VHDL Type Mismatch error at bcff.vhd(46): indexed name returns a value whose type does not match "std_logic_vector", the type of the target expression). Could you please look at the two files for me and try to fix the bug. Also I want to know if the current design has the bus_relay pass signals from IO1 to IO2 and vice versa. I am not sure that the signal is propagating properly. Would you look into this for me and fix the error. Thanks. Lewis.Link Copied
nice error, since the file only has 44 lines.
[edit] you assign a single bit to a std_logic_vector and that is not valid. [/edit]- Mark as New
indexing into an array gives you a single element of the array, which in this case is a std_logic. The component expects a std_logic_vector of length 1 (because N defaults to 1). So you need to pass it:
LIN(0 downto 0)- Mark as New
--- Quote Start --- indexing into an array gives you a single element of the array, which in this case is a std_logic. The component expects a std_logic_vector of length 1 (because N defaults to 1). So you need to pass it: LIN(0 downto 0) --- Quote End --- Hi. Thanks for the feedback. Could you give me an example in the form of the full source code. Thanks.
