VHDL and Megafunctions
Need help using Megafunctions with my VHDL code. I have used the Megafunction Wizard and it is now in my files list but how to I bring the signals into my top level design. can someone tell me the step-by-step procedure to get this working. Below would be the basic structure for
my code.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity PCIad is port(
end PCIad;
architecture archPCIad of PCIad is
begin
end archPCIad;
The Quartus VHDL editor's template tool includes several examples of Megafunction instantiation.
On the MegaWizard Summary page, enable generation of the .cmp and _inst.vhd files. Insert these into your own VHDL file where you need the component declaration and the component instantiation. Then edit the signal names for the instantiation to match your own names.
Thank you for responding.
At the bottom are the three files the the wizard generated. Where should
they be placed. Sorry for being lame but I have still not got this to work.
library ieee;
end PCIad;
begin
end archPCIad;
component ALT_PLL
PORT
areset : IN STD_LOGIC := '0';
inclk0 : IN STD_LOGIC := '0';
c0 : OUT STD_LOGIC ;
locked : OUT STD_LOGIC
end component;
FUNCTION ALT_PLL (areset, inclk0)
RETURNS (c0, locked);
ALT_PLL_inst : ALT_PLL PORT MAP (
areset => areset_sig,
inclk0 => inclk0_sig,
c0 => c0_sig,
locked => locked_sig
It should look like this
library ieee;
areset_sig: in STD_LOGIC;
inclk0_sig: in STD_LOGIC;
c0_sig: out STD_LOGIC;
locked_sig: out STD_LOGIC
end PCIad;
component ALT_PLL
PORT
end component;
begin
c0 => c0_sig,
end archPCIad;
It looks like you are figuring it out.
You can of course change the *_sig names and the ALT_PLL_inst name to be anything you want. The MegaWizard _inst.vhd file used these as placeholders for the names of your choice.
you can avoid copying the component declaration alltogether, by doing direct instantiation:
library ieee;
end PCIad;
begin
ALT_PLL_inst : entity work.ALT_PLL --this is the direct bit
PORT MAP (
c0 => c0_sig,
end archPCIad;
Again, you can even avoid using the wizard by using the altera_mf library. It gives me more direct control, and less extra rubbish/wrappers cluttering up my working directory (though I know some people prefer setting stuff up via the wizard):
library altera_mf;
use altera_mf.altera_mf_components.all;
--this comes from the altera_mf library
ALT_PLL_inst : altpll
generic map (
OPERATION_MODE => "NORMAL",
PORT MAP (
c0 => c0_sig,
all of the generics can be found via help -> megafunctions/lpm.
--- Quote Start ---
--- Quote End ---
Be aware that the altera_mf library is functional simulation models. It is not intended for synthesis.
The MegaWizard has the advantage of preventing some illegal combinations of parameter settings. If you choose to instantiate megafunctions directly instead of using a MegaWizard variation file, you can still create a MegaWizard variation file to get a correct set of parameters/generics that you can copy to your own file where you are instantiating the megafunction like altpll directly. If you don't use the MegaWizard at all, then see the on-line help page for the megafunction as Tricky mentioned or see the user guide for it at http://www.altera.com/literature/lit-ip.jsp to see what the available ports and parameters/generics are.
