VHDL and Transposed Fir
Hello guys ,
I'm implementing a transposed fir filter in vhdl in which only the sum are pipelined.
The code I wrote up (using this (http://www.google.it/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0cdaqfjac&url=http%3a%2f%2fwww4.hcmut.edu.vn%2f~hoangtrang%2flecture%2520note%2fdsp%2520on%2520fpga%2fdsp_fpga_ch%252010%2520-%2520fir%2520filter%2520design.pdf&ei=a76eu6uummnp4qt88yggba&usg=afqjcnhr62rzy5-5rvzgccd0nxqz9xaoow&bvm=bv.68911936,d.bge)) until now is the one below:
LIBRARY lpm; USE lpm.lpm_components.ALL; LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.all; ENTITY transposed_fir_test IS GENERIC (W1 : INTEGER := 16; -- Input bit width W2 : INTEGER := 32; -- Multiplier bit width W3 : INTEGER := 35; -- Adder width W4 : INTEGER := 16; -- Output bit width L : INTEGER := 15; -- Filter length Mpipe : INTEGER := 0-- Pipeline steps of multiplier ); PORT ( clk : IN STD_LOGIC; Load_x : IN STD_LOGIC; x_in : IN STD_LOGIC_VECTOR(W1-1 DOWNTO 0); c_in : IN STD_LOGIC_VECTOR(W1-1 DOWNTO 0); y_out : OUT STD_LOGIC_VECTOR(W4-1 DOWNTO 0)); END transposed_fir_test; ARCHITECTURE fpga OF transposed_fir_test IS SUBTYPE N1BIT IS STD_LOGIC_VECTOR(W1-1 DOWNTO 0); SUBTYPE N2BIT IS STD_LOGIC_VECTOR(W2-1 DOWNTO 0); SUBTYPE N3BIT IS STD_LOGIC_VECTOR(W3-1 DOWNTO 0); TYPE ARRAY_N1BIT IS ARRAY (0 TO L-1) OF N1BIT; TYPE ARRAY_N2BIT IS ARRAY (0 TO L-1) OF N2BIT; TYPE ARRAY_N3BIT IS ARRAY (0 TO L-1) OF N3BIT; SIGNAL x : N1BIT; SIGNAL y : N3BIT; SIGNAL c : ARRAY_N1BIT; -- Coefficient array SIGNAL p : ARRAY_N2BIT; -- Product array SIGNAL a : ARRAY_N3BIT; -- Adder array BEGIN Load: PROCESS ------> Load data or coefficient BEGIN WAIT UNTIL clk = '1'; IF (Load_x = '0') THEN c(L-1) <= c_in; -- Store coefficient in register FOR I IN L-2 DOWNTO 0 LOOP -- Coefficients shift one c(I) <= c(I+1); END LOOP; ELSE x <= x_in; -- Get one data sample at a time END IF; END PROCESS Load; SOP: PROCESS (clk) ------> Compute sum-of-products BEGIN IF rising_edge(clk) THEN FOR I IN 0 TO L-2 LOOP -- Compute the transposed a(I) <= std_logic_vector(signed(p(I)) + signed(a(I+1))); -- filter adds END LOOP; a(L-1) <=std_logic_vector(resize(signed(p(L-1)),W3)); -- First TAP has END IF; -- only a register y <= a(0); END PROCESS SOP; -- Instantiate L pipelined multiplier MulGen: FOR I IN 0 TO L-1 GENERATE Muls: lpm_mult -- Multiply p(i) = c(i) * x; GENERIC MAP ( LPM_WIDTHA => W1, LPM_WIDTHB => W1, LPM_PIPELINE => Mpipe, LPM_REPRESENTATION => "SIGNED", LPM_WIDTHP => W2, LPM_WIDTHS => W2) PORT MAP ( dataa => x, datab => c(I), result => p(I)); END GENERATE; y_out <=y(W3-1 DOWNTO W3-W4); END fpga;
By the way using a delta-stimulus of 32767 and this set of coeff: [32437,31463,29888,27779,25230,22351,19269,16118,13036,10157,7608,5500,3924,2950,2621] I get the following output:
[X,X,X,X,X,1576,1396,1204,1007,814,634,475,343,245,184,163,0]
So it seems I miss the first ouptut samples of the filter and a scaled output..
Any suggestions ??
ty !
to get initial values correctly you need to set accumulators to zero start.
you are scaling by discarding 19 bits. Is that what you wanted?
--- Quote Start ---
--- Quote End ---
Yep, those X's are related to the initial values of the C matrix.
As long as I need only 16 bit I have to take only the MSbs at the output. The magnitude is ok. I was a little confused because the very first values at the output of the filter where not shown due to the lack of initialization of the C matrix.
One curiosity, now the filter coefficient are uploaded at the same clock of the input signal. By the way I want to control the coefficient uploading with a different clock (I want to set the coefficient via NIOS PIOs).
I've thought to use a first pio to load the coefficient into c_in and a secondo pio to get the c_in loaded (so it acts like the clock of the previus code). I ended up with this code:
-- This is a generic FIR filter generator -- It uses W1 bit data/coefficients bits LIBRARY lpm; -- Using predefined packages USE lpm.lpm_components.ALL; LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.all; ENTITY transposed_fir_test IS ------> Interface GENERIC (W1 : INTEGER := 16; -- Input bit width W2 : INTEGER := 32; -- Multiplier bit width 2*W1 W3 : INTEGER := 35; -- Adder width = W2+log2(L)-1 W4 : INTEGER := 16; -- Output bit width L : INTEGER := 15; -- Filter length Mpipe : INTEGER := 0-- Pipeline steps of multiplier ); PORT ( clk : IN STD_LOGIC; rst : IN STD_LOGIC; Load_x : IN STD_LOGIC; x_in : IN STD_LOGIC_VECTOR(W1-1 DOWNTO 0); c_in : IN STD_LOGIC_VECTOR(W1-1 DOWNTO 0); wr_clk : IN STD_LOGIC; y_out : OUT STD_LOGIC_VECTOR(W4-1 DOWNTO 0)); END transposed_fir_test; ARCHITECTURE fpga OF transposed_fir_test IS SUBTYPE N1BIT IS STD_LOGIC_VECTOR(W1-1 DOWNTO 0); SUBTYPE N2BIT IS STD_LOGIC_VECTOR(W2-1 DOWNTO 0); SUBTYPE N3BIT IS STD_LOGIC_VECTOR(W3-1 DOWNTO 0); TYPE ARRAY_N1BIT IS ARRAY (0 TO L-1) OF N1BIT; TYPE ARRAY_N2BIT IS ARRAY (0 TO L-1) OF N2BIT; TYPE ARRAY_N3BIT IS ARRAY (0 TO L-1) OF N3BIT; SIGNAL x : N1BIT; SIGNAL y : N3BIT; SIGNAL c : ARRAY_N1BIT; -- Coefficient array SIGNAL p : ARRAY_N2BIT; -- Product array SIGNAL a : ARRAY_N3BIT; -- Adder array BEGIN x <= x_in; Load: PROCESS(wr_clk,Load_x) ------> Load data or coefficient BEGIN if(rising_edge(wr_clk)) then IF (Load_x = '0') THEN c(L-1) <= c_in; -- Store coefficient in register FOR I IN L-2 DOWNTO 0 LOOP -- Coefficients shift one c(I) <= c(I+1); END LOOP; ELSE ; END IF; end if; END PROCESS Load; SOP: PROCESS (clk) ------> Compute sum-of-products BEGIN IF rising_edge(clk) THEN FOR I IN 0 TO L-2 LOOP -- Compute the transposed a(I) <= std_logic_vector(signed(p(I)) + signed(a(I+1))); -- filter adds END LOOP; a(L-1) <=std_logic_vector(resize(signed(p(L-1)),W3)); -- First TAP has END IF; -- only a register y <= a(0); END PROCESS SOP; -- Instantiate L pipelined multiplier MulGen: FOR I IN 0 TO L-1 GENERATE Muls: lpm_mult -- Multiply p(i) = c(i) * x; GENERIC MAP ( LPM_WIDTHA => W1, LPM_WIDTHB => W1, LPM_PIPELINE => Mpipe, LPM_REPRESENTATION => "SIGNED", LPM_WIDTHP => W2, LPM_WIDTHS => W2) PORT MAP ( dataa => x, datab => c(I), result => p(I)); END GENERATE; y_out <=y(W3-1 DOWNTO W3-W4); END fpga;
Any suggestions ?
What can I do if I want to intialize to 0's the C matrix while resetting ?
ty !
to initilaise use := (others => (others => '0'));
your dividing by 2^19 may not be right for unity gain. Your output will be scaled somewhere above or below unity
Thank you kaz !
I have never understand if that type initialization is true also during the power up .. could you confirm it ?
--- Quote Start ---
Thank you kaz !
--- Quote End ---
yes it is supported as initial values on registers at powerup
