I am not expert in VHDL, and I got stuck with this problem. In the original code 'fifo_data_out' was defined as 24 bit (INPUT_DATAWIDTH = 24) and the compilation was successful
SIGNAL fifo_data_out : STD_LOGIC_VECTOR(INPUT_DATAWIDTH-1 DOWNTO 0);
I just changed INPUT_DATAWIDTH to 16, then the compilation was not successful as shown in the below picture, can some body explain to me, why? https://www.alteraforum.com/forum/attachment.php?attachmentid=8885
at least look here but you need care about these variables:
master_writedata <= "00000000" & fifo_data_out; and check the widths. 24 + 8 = 32 16+8 = 24- Mark as New
Yes,
try
master_writedata <= ( INPUT_DATAWIDTH-1 DOWNTO 0 => fifo_data_out, others => '0'); -- assign "fifo_data_out" to the LSB of "master_write_data"
I saw those zeros as Hex value......you are right.
Thanks :)- Mark as New
--- Quote Start --- I saw those zeros as Hex value......you are right. Thanks :) --- Quote End --- while applying user variable widths and other variable parameters is necessary for ips but for individual modules I don't not see it as needed and I have almost never seen any local parameterised modules to work if I change a parameter because of dependency and lack of testing. I already noticed your fifo is actually fixed to 16 bits and the parameter is not used.
Hi mmTsuchi,
Your solution is more practical. fifo_data_out is defined as
and I am getting this error on Quartus --- Quote Start --- Error (10476): VHDL error at ADC_Burst_Write_Master.vhd(193): type of identifier "fifo_data_out" does not agree with its usage as "std_ulogic" type --- Quote End --- How to work around it?
--- Quote Start --- Hi mmTsuchi, Your solution is more practical. fifo_data_out is defined as
and I am getting this error on Quartus How to work around it? --- Quote End --- I think that statement posted means bit by bit mapping. You better just use: <= x"0000" & fifo_data_out;
