17267 讨论
VHDL hierarchical project design problem in Quartus II Web Edition 11.0(With SP1)
名誉分销商 II
2,385 次查看
The problem is:
1. Create 1st VHDL project and create BSF - Ok
2. Create 2nd VHDL project and create BSF - Ok
3. Create 3rd project:
- Add 1st and 2nd project (through LIBRARIES setting menu) - set path to my projects. Ok
- Create BDF-file for 3rd projet - Ok
- Call Symbol Tool in order to add my 1st and 2nd BSFs-files - Ok
- Add my 1st project (which is upper in Libraries list) - Ok
- Add my 2nd project (which is in the bottom of my "libraries files" list) - FAILED
So if I change order of 1st and 2nd project (change their place in "libraries files" list) then the Quartus can`t find 1st project.
So the problem is that Quartus can`t find projects specified in global (project) libraries that are not on the first position.
Any ideas?
0 项奖励
4 回复数
名誉分销商 II
1,439 次查看
have you tried doing it all in VHDL?
0 项奖励
名誉分销商 II
1,439 次查看
--- Quote Start ---
--- Quote End ---
Yes, I have.
In VHDL coding style all is Ok and works fine. But in BDF like style I have problems.
0 项奖励
名誉分销商 II
1,439 次查看
try using relative path i.e.
for example use
..\project1
instead of
c:\myprojects\top\project1
0 项奖励
名誉分销商 II
1,439 次查看
--- Quote Start ---
for example use
..\project1
instead of
--- Quote End ---
It doesn`t work too.
The only way to use BSF as a library module in my top-level BDF project is to specify project libraries, but not Global Libraries. Are there any features that I don`t know about Global and Project Libraries. Because for VHDL like projects (where top-level modules are also in VHDL) I always use Global Libraries and I have no problems, but in BDF like top-module projects i have the problem specified above.
0 项奖励
回复
