VHDL "EVENT" Problem
Hello, I'm a beginner for using Quartus II. I have an error in this VHDL code
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity Test is
port(clk : in std_logic;
preset : in std_logic;
flag : in std_logic;
out : out std_logic_vector(15 downto 0);
done : out std_logic
end Test;
architecture RTL of Test is
signal d :std_logic_vector(15 downto 0);
signal q :std_logic_vector(15 downto 0);
signal I :std_logic_vector(15 downto 0) := "0111010101001101";
signal flag_sgl : std_logic ;
signal done_sgl, VI, : std_logic;
begin
process(clk,flag)
begin
if(preset= '0') then
flag_sgl <= '0';
done_sgl <= '0';
VI <= '1';
elsif (clk'event and clk='1') then
VI <= '0';
if (flag_sgl = '1')then
flag_sgl <= '0';
done <= not(done_sgl);
done_sgl <= not(done_sgl);
out <= q(15 downto 0);
q <= d;
end if;
end if;
if (flag'event ) then
flag_sgl <= '1';
end if;
end process ;
d(0) <= I(0) when VI = '1' else q(1) ;
d(1) <= I(1) when VI = '1' else q(2) ;
d(2) <= I(2) when VI = '1' else q(0) xor q(3) ;
d(3) <= I(3) when VI = '1' else q(4) ;
d(4) <= I(4) when VI = '1' else q(5) ;
d(5) <= I(5) when VI = '1' else q(6) ;
d(6) <= I(6) when VI = '1' else q(0) xor q(7) ;
d(7) <= I(7) when VI = '1' else q(8) ;
d(8) <= I(8) when VI = '1' else q(9) ;
d(9) <= I(9) when VI = '1' else q(0) xor q(10);
d(10) <= I(10) when VI = '1' else q(11) ;
d(11) <= I(11) when VI = '1' else q(0) xor q(12);
d(12) <= I(12) when VI = '1' else q(13) ;
d(13) <= I(13) when VI = '1' else q(14);
d(14) <= I(14) when VI = '1' else q(0) xor q(15);
d(15) <= I(15) when VI = '1' else q(0);
end architecture RTL;
I got a problem in the "RED" color line.
I would like "flag_sgl" change value to '1', everytime that input signal "flag" change its value.
Are there any way for detecting "flag" changing without using 'EVENT?
Thank you in advance ^^
Using edge like that translates to clock port signal with its rules. Better detect change of value:
inside process
flag_d <= flag;
if flag /= flag_d then
end if;
process(preset, clk)
