Verilog Error
Could you please let me know how to declare a synthesizable array of constants? The constants are shown in the define directive. The below is giving an error. I am new to verilog .
`define DATA_0 1
`define DATA_1 2
`define DATA_2 4
`define DATA_3 8
`define DATA_4 16
`define DATA_5 32
`define DATA_6 64
`define DATA_7 128
module IRC (......);
input x,y,z;
out alpha, beta;
reg alpha, beta;
reg [7:0] IDATA [31:0] = {DATA_0, DATA_1, DATA_2, DATA_3, DATA_4, DATA_5, DATA_6, DATA_7};
begin
endmodule
The trouble is not your defines. With Verilog, you cannot initialise a 2D array in that way.
You should instead use an initial block:
initial begin IDATA = DATA_0; IDATA = DATA_1; ... end
Also, you appear to have only 8 initialisation values, but there are 32 elements in the array to be initialised.
also
you need apostrophe in front of define symbol.
like ...
IDATA[0] = `DATA_0;
Thanks, it helped me a lot.
I have prepared a script file and am now compiling the files. The commands in the script are as shown below
vlog -reportprogress 300 -work work "C:/work/aaa/bbb/ccc/ddd/xly/AIC_package.v"
vlog -reportprogress 300 -work work "C:/work/aaa/bbb/ccc/ddd/xly/AICController.v"
vlog -reportprogress 300 -work work "C:/work/aaa/bbb/ccc/ddd/xly/sim/AIC_tb.v"
# Modifying modelsim.ini
# Model Technology ModelSim PE vlog 10.1b Compiler 2012.04 Apr 27 2012
# ** Error: C:/work/aaa/bbb/ccc/ddd/xly/AICController.v(18): Cannot open `include file "C:/modeltech_pe_10.1b/uvm-1.1a/../verilog_src/uvm-1.1a/src/AIC_package.v".
# -- Compiling module AICController
I could not figure out why its not getting the include file AIC_Package.v
where did you put the file?
try ls command (or dir command in Windows)
if the path C:/modeltech_pe_10.1b/uvm-1.1a/../verilog_src/uvm-1.1a/src/AIC_package.v exists ore not?
source files are in C:/work/aaa/bbb/ccc/ddd/xly and testbench in C:/work/aaa/bbb/ccc/ddd/xly/sim.
The script is run from C:/work/aaa/bbb/ccc/ddd/xly/sim
The script contains the following
vsim work.AIC_tb.
I am confused about this path. This does not exist. Actually the file AIC_package.v is never placed in the folder where ModelSim is reporting error. Its placed alongside its main file AICController.v in C:/work/aaa/bbb/ccc/ddd/xly.
you should try to create the folder and put the file "AIC_package.v "
I think then the simulation works.
just for now , that is enough for you isn't it?
try it anyway.
What folder to creat? if this is C:/work/aaa/bbb/ccc/ddd/xly, its already created. Also work directory is also created.
the folder you missed.
the message tells you "C:/modeltech_pe_10.1b/uvm-1.1a/../verilog_src/uvm-1.1a/src/AIC_package.v "
which means "C:/modeltech_pe_10.1b/verilog_src/uvm-1.1a/src/AIC_package.v "
I don't know why modelsim requires that path.
but the message tells you, you need it anyway.
just try it and research the reason in someday later.
