Hi All,
I have a working piece of code : if(in_I & in_Q) cnt <= cnt + `INC_SIZ; if(in_I & !in_Q) cnt <= cnt - `INC_SIZ; if(!in_I & in_Q) cnt <= cnt - `INC_SIZ; if(!in_I & !in_Q) cnt <= cnt + `INC_SIZ; in an attempt to be clever, I changed it to if(in_I ^ in_Q) begin cnt <= cnt + `INC_SIZ; end else begin cnt <= cnt - `INC_SIZ; end which stopped working. in_I and in_Q are single bit input ports. What am I doing that is daft, the logic looks OK to me. Thanks, MarkLink Copied
I don't know. I use a similar construct with ^ operator and it works.
Did you try if(in_I != in_Q) ? It should be the same. I'm assuming all this is in a always@(posedge clk) block. Is this correct? Or maybe is always@(in_I or in_Q) ? Just a remark: I'm rather concerned about the first piece of code (working). I'd have written it: if... else if...else if... else- Mark as New
Your first logic is equivalent to this below:
if(in_I ^ in_Q) begin cnt <= cnt - `INC_SIZ; end else begin cnt <= cnt + `INC_SIZ; end- Mark as New
Hi guys,
Thanks for your thoughts. I tried changing xor to == and != without success. Here are the full modules. All I am doing is building an up/down counter based on inputs from an I/Q rotary shaft encoder. I and Q do not change together. There are two cascaded meta stability D latched between this module and the hardware. I am not worried about direction of count and the final output assignments are just sample probes at the moment. One module works, the other does not. Compilation size is also different - I was expecting them to compile to same code. Regards, Mark ========= works //----------------------------------------------------- // IQ counter //----------------------------------------------------- module IQ_ctr(in_I, in_Q, clk, out_0, out_1); `define INC_SIZ 16'd125 //----------Output Ports-------------- output out_0; output out_1; //------------Input Ports-------------- input in_I, in_Q, clk; //------------Internal Variables-------- reg out_0; reg out_1; reg [16:0] cnt; reg last_I; reg last_Q; //-------------Code Starts Here------- always @(posedge clk) begin if(in_I ^ last_I) // I changed begin if(in_I & in_Q) cnt <= cnt + `INC_SIZ; if(in_I & !in_Q) cnt <= cnt - `INC_SIZ; if(!in_I & in_Q) cnt <= cnt - `INC_SIZ; if(!in_I & !in_Q) cnt <= cnt + `INC_SIZ; end if(in_Q ^ last_Q) // Q changed begin if(in_Q & in_I) cnt <= cnt - `INC_SIZ; if(in_Q & !in_I) cnt <= cnt + `INC_SIZ; if(!in_Q & in_I) cnt <= cnt + `INC_SIZ; if(!in_Q & !in_I) cnt <= cnt - `INC_SIZ; end last_I <= in_I; last_Q <= in_Q; out_0 = cnt[15]; out_1 = cnt[14]; end endmodule ========= does not work //----------------------------------------------------- // IQ counter //----------------------------------------------------- module IQ_ctr(in_I, in_Q, clk, out_0, out_1); `define INC_SIZ 16'd125 //----------Output Ports-------------- output out_0; output out_1; //------------Input Ports-------------- input in_I, in_Q, clk; //------------Internal Variables-------- reg out_0; reg out_1; reg [16:0] cnt; reg last_I; reg last_Q; //-------------Code Starts Here------- always @(posedge clk) begin if(in_I ^ last_I) // I changed begin if(in_I != in_Q) cnt <= cnt - `INC_SIZ; else cnt <= cnt + `INC_SIZ; end if(in_Q ^ last_Q) // Q changed begin if(in_I != in_Q) cnt <= cnt + `INC_SIZ; else cnt <= cnt - `INC_SIZ; end last_I <= in_I; last_Q <= in_Q; out_0 = cnt[15]; out_1 = cnt[14]; end endmodule- Mark as New
Arrgh, busted hardware !
That was quite a waste of a few hours. The problem really smelt like a compiler bug. Change to new hardware and everything looks OK. Regards, Mark
