Verilog coding issue
:confused::confused:Hello everyone
can some buddy guide me how initialize your own data set in verilog with complete sample example. I have written a code but getting error
module mean(A1,A2,A3,B1,B2,B3,C1,C2,C3,D1,D2,D3,M1,M2,M3);
input A1,A2,A3,B1,B2,B3,C1,C2,C3,D1,D2,D3;
output M1,M2,M3;
reg A1[50][1]='{51,49,47,46,50,54,46,50,44,49,54,48,48,43,58,57,54,51,57,51,54,51,46,51,48,50,50,52,52,47,48,54,52,55,49,50,55,49,44,51,50,45,44,50,51,48,51,46,53,50};
reg A2[50][1]='{70,64,69,55,65,57,63,49,66,52,50,59,60,61,56,67,56,58,62,56,59,61,63,61,64,66,68,67,60,57,55,55,58,60,54,60,67,63,56,55,55,61,58,50,56,57,57,62,51,57};
reg A3[50][1]='{63,58,71,63,65,76,49,73,67,72,65,64,68,57,58,64,65,77,77,60,69,56,77,63,67,72,62,61,64,72,74,79,64,63,61,77,63,64,60,69,67,69,58,68,67,67,63,65,62,59};
reg B1[50][1]='{35,30,32,31,36,39,34,34,29,31,37,34,30,30,40,44,39,35,38,38,34,37,36,33,34,30,34,35,34,32,31,34,41,42,31,32,35,36,30,34,35,23,32,35,38,30,38,32,37,33};
reg B2[50][1]='{32,32,31,23,28,28,33,24,29,27,20,30,22,29,29,31,30,27,22,25,32,28,25,28,29,30,28,30,29,26,24,24,27,27,30,34,31,23,30,25,26,30,26,23,27,30,29,29,25,28};
reg B3[50][1]='{33,27,30,29,30,30,25,29,25,36,32,27,30,25,28,32,30,38,26,22,32,28,28,27,33,32,28,30,28,30,28,38,28,28,26,30,34,31,30,31,31,31,27,32,33,30,25,30,34,30};
reg C1[50][1]='{14,14,13,15,14,17,14,15,14,15,15,16,14,11,12,15,13,14,17,15,17,15,10,17,19,16,16,15,14,16,16,15,15,14,15,12,13,14,13,15,13,13,13,16,19,14,16,14,15,14};
reg C2[50][1]='{47,45,49,40,46,45,47,33,46,39,35,42,40,47,36,44,45,41,45,39,48,40,49,47,43,44,48,50,45,35,38,37,39,51,45,45,47,44,41,40,44,46,40,33,42,42,42,43,30,41};
reg C3[50][1]='{60,51,59,56,58,66,45,63,58,61,51,53,55,50,51,53,55,67,69,50,57,49,67,49,57,60,48,49,56,58,61,64,56,51,56,61,56,55,48,54,56,51,51,59,57,52,50,52,54,51};
reg D1[50][1]='{02,02,02,02,02,04,03,02,02,01,02,02,01,01,02,04,04,03,03,03,02,04,02,05,02,02,04,02,02,02,02,04,01,02,02,02,02,01,02,02,03,03,02,06,04,03,02,02,02,02};
reg D2[50][1]='{14,15,15,13,15,13,16,10,13,14,10,15,10,14,13,14,15,10,15,11,18,13,15,12,13,14,14,17,15,10,11,10,12,16,15,16,15,13,13,13,12,14,12,10,13,12,13,13,11,13};
reg D3[50][1]='{25,19,21,18,22,21,17,18,18,25,20,19,21,20,24,23,18,22,23,15,23,20,20,18,21,18,18,18,21,16,19,20,22,15,14,23,24,18,18,21,24,23,19,23,25,23,19,20,23,18};
endmodule
:confused:
thanks in advance
What error are you getting? You've defined the inputs and outputs as single bit, but it seems like you're trying to create each as a 50 element memory?
I am getting syntax error though I tried my best to remove it but could not so can give me complete sample example like that which is synthesizable.
thanks
yes wanna to creat 50 element memory
Couple of different ways to do it, either all in verilog or with using a text file to init the memory contents.
So you can do this in verilog to initialize the block memory device memdat from the contents of a file:
reg memdat; initial $readmemb("meminit.txt", memdat, 0, 4095);
where the file meminit.txt contains 4096 lines of data (in this case 12bit binary strings since I used $readmemb):
000000000000 011000110001 111111000001 ... 111111111111
or instead of that initial block that uses an external text file, you could use plain old verilog assignment statements:
initial begin memdat = 12'hFFF; memdat = 12'b0000_1111_0000; ... memdat = 12'd1234; end
or a more complex set of verilog code:
initial begin : init_block integer i; for (i = 0; i < 4096; i = i+1) memdat = 12'h000; memdat = 12'd1234; ... etc end
thank you very much can you tell me text file can contain integers ? and what will be the path of text file?
--- Quote Start ---
--- Quote End ---
The default location of the file will be in the current project directory.
As to other data formats the answer is there are two versions of the memory access function: $readmemb expects a binary string format, and $readmemh expects a hex string format. There is no version that will expect decimal strings, which I assume is what you mean by 'integer' format.
