can anybody help me? I'm trying to compile and run some OpenCL codes in Visual Studio. I have not been successful so far. Worse, my video card burned. The current specifications of my PC (without offboard video card) are as follows: Windows 8.1 Pro 64-bit Intel Core 2 Quad CPU Q6600 @ 2.4GHz, 4.0GB RAM, Intel G33 / G31 Express Chipset Family With these specifications I can program in OpenCL in Visual Studio? What do I need to do? I'm totally lost. If in case it is not possible in Visual Studio, is there any way I can get OpenCL on my machine? Thanks in advance for your help and attention.Link Copied
Do you have an FPGA board or are you just trying to use OpenCL on your machine? If it is the former case, read this (https://www.altera.com/en_us/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf) document. If it is the latter case, you can try using OpenCL on your CPU; however, that would be completely unrelated to this forum since this forum is for using OpenCL on Altera's FPGA boards.
