17253 Discussions
Want to make AS programming on de2 board
I have complete file of vhdl file and that works successfully on my de2 board.
but I want to make AS programming that need .pof filename extension.
i changed that extension my file but it cannot open on software.
plz tell me how to make this.
thx sir :)
These are two different file formats. Changing the extension won't work. See the DE2 documentation for the procedure used to flash a configuration to the board.
Hi sir
I didn't get you ?
I have .qpf file extension.
I already read the de2 user manual. I don't know how to make .pof from .qpf
If I get .pof then I know how to run with de2 board.
Plz help me
Converting an SOF file to a POF is described in the Quartus II documentation. You use "File -> Convert Programming Files".
Thx sir
But I saw conversation setup file is (.cof).
What is that
I don't have this file extension
I converted sof file to pof
And I run the program
It shows "cannot add flash memory programmer object file at the top level"
What is that
Sir...
