17255 Discussions
Warning (18029): Output pin [...] cannot be tri-stated
I get the following warning (for each line of "Data") in my design:
"Warning (18029): Output pin "_subnet_pin_406" driven by bidirectional pin "Data(0)" cannot be tri-stated"
"Data" is a bidirectional bus, the Pins should be tristated, when the FPGA makes a read access. I'm working with a Cyclone III and Quartus 12.0SP2. The Design seems to work on my board, and the RLT schematic shows tristate buffers at the outputs.
The Quartus help says:
CAUSE:
The specified output pin is driven by both the specified bidirectional pin and tri-stated logic. However, the current device does not support a tri-stated output pin. When the output pin is not driven by either the logic or the bidirectional pin, its output value is undefined.
ACTION:
If the output pin is always driven by either the logic or the bidirectional pin, no action is required. Otherwise, insert an extra tri-state buffer before the output pin.
I don't understand, what the quartus help wants to say. The sentence doesn't make much sense to me... ;-)
can anyone help me to understand the warning?
Ego
Hi, please post code or schema to help you more.
(How do you declare those pins ?)
--- Quote Start ---
--- Quote End ---
I also have this problem.I doubt that what Output pin "_subnet_pin_406" means. Where is _subnet_pin_406 ?I can't find it in the design.
I also have this problem. I'm using Quartus 13.0 and I'm targetting a Cyclone IV GX.
I simplified my design to this:
escc_data_out <= "00010100"; ESCC_DATA <= escc_data_out when blink = '0' else "ZZZZZZZZ";
ESCC_DATA is also used as an input somewhere in the design.
I get some warning for the whole bus:
Warning (18029): Output pin "pre_syn.bp.ESCC_CTRL_ESCC_DATA_IN_0_" driven by bidirectional pin "ESCC_DATA" cannot be tri-stated
The RTL view seems correct:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8278
However, the post mapping view shows some strange things. Sometimes the blink signal is connected to the tri-state buffer enable pin, sometimes it is connected to the tri-state buffer input.
If I don't use ESCC_DATA as an input, I don't have warnings anymore.
Any idea ?
Franck.
There is something about this in the Altera Knowledge Base: http://www.altera.com/support/kdb/solutions/rd11152011_728.html
However, I resolved this problem (warning) using the Megawizard generated ALTIOBUF configured for bidirectional operation.
Franck.
