17267 Discussions
What file does pin planner modify?
When I launch the pin planner from within Quartus, another application pops open. From that app, I can modify the pin assignment and other properties. There is no 'file save' operation. It just seems to modify something as I'm making changes. If I quit the pin planner, those changes just seem to 'take'
What is this modifying?
the Quartus Settings File (.qsf)
All assignments (for pin locations, I/O standards and more), including those made by the pin planner, are stored in the current project revision's *.qsf file. They are readable (tcl commands) text and can be inspected, copied, and - if you like - manually edited (as long as the project isn't opened). The *.qsf file is automatically updated when closing the project.
You can edit the .qsf even in the opened project (inside Quartus or external), it will take precedence.
Hi sorry to bump an old thread, but i have some problems with the pin planner. The .qsf get updated when i close the pin planner, but when i open the pin planner and click on the early pin assignment, the setting from last are not there. any inputs on how to fix this is appreciated.
/stefan
