17268 Discussions
What's the Altera Equivalent to the Xilinx STARTUP Primitive GSR/GlobalSetReset?
Here's an example of what it looks like for Xilinx:
// Instantiating STARTUP symbol
STARTUP U1 (.GSR(global_reset));
always @(posedge clk or posedge global_reset) begin
if (global_reset) begin
dff <= 1'b0;
end
else begin
dff <= xyz;
end
end
Ok...Altera how to do it without needing a clock and initial conditions to create a global reset?
The reason why I ask is because I have a QSYS with an HPS core that is outputing a clock from a pll and the top-level FPGA doesn't have a Clock or reset pin that is accessable to the FPGA logic...
To answer your main question - there is no Altera equivalent to the GSR primitive.
You should be able to route the clock and a reset signal from the HPS to the FPGA fabric directly. What problem are you having? Export the signals in Qsys and then in the top-level HDL wrapper (I assume) that instantiates your Qsys module and your FPGA module just wire the clock and reset from the Qsys module to the FPGA module.
