as from subj, I'm not finding the info of which OpenCL release is Altera conformant to (OpenCL 1.0, 1.1, etc...), where can I get it? Thanks LucaLink Copied
Please see appendix A (Support Statuses of OpenCL Features) in the OpenCL programming guide.
Indeed it is conformant to version 1.0, but there are a few implemented features from 1.2 and 2.0. They are described in appendix of this document (https://www.altera.com/en_us/pdfs/literature/hb/opencl-sdk/aocl_programming_guide.pdf).
Hi guys,
Do you know if there are plans to fully upgrade to 2.0 or 2.1? If so, do you have an approximate timeline of when this would be? thanks SL- Mark as New
Bump.. Any thoughts?
Even a 'we don't plan to ever implement this' would be interesting --- Quote Start --- Hi guys, Do you know if there are plans to fully upgrade to 2.0 or 2.1? If so, do you have an approximate timeline of when this would be? thanks SL --- Quote End ---- Mark as New
Well you clould ask Altera...
I thought I was :-)
Is there a better place to do so? I guess i'm interested too in if this is something that could be expected - ie if anyone else would use it as well.- Mark as New
I would file a request with Altera support.
Not sure why they're not keen on replying here - it's the first place that the altera site points you to.
A simple yes/no and date would suffice and would give be much more useful than a vacuum of uncertainty. Anyway, ta, I'll chase them up externally
